kamast
Boeing 737-700 max cargo hold capacity
Sat Mar 03, 2018 4:00 pm
Hi everybody,
Do someone know about how many standard lugage can be loaded max on B737-700 hold compartment ? I know capacity its 27 cbm or 5180 kg but would like to Knox how many pc bagage that represent.
Acey
Re: Boeing 737-700 max cargo hold capacity
Sat Mar 03, 2018 4:26 pm
Very approximate and depends on a number of factors, but I would say ~120 bags in the back and ~50 in the front.
If a man hasn't discovered something that he will die for, he isn't fit to live. -- Martin Luther King, Jr.
Mutt
Sun Mar 04, 2018 1:43 am
I often throw the bags, and I would guess ~100 front, ~80 rear. If no one gives a definitive answer by the time I start my next trip, I'll find out.
george77300
Mon Mar 05, 2018 8:08 am
Interesting of the two comments above one thinks front is bigger and the other rear is bigger. I have no idea myself but thought interesting.
A306 A313 A319 A320 A321 A332 A333 A343 A345 A346 A388
B712 B733 B734 B735 B738 B742 B744 B752 B763 B772 B77E B773 B77W
AT75 AT76 C208 P46T SR20 SR22 TBM8
BA EI EK EY FR GT IG JQ KX PG PW QF QR SQ TG TP U2 UA VS WY ZB
Mon Mar 05, 2018 8:29 am
It maybe not which is larger, just were the weight needs to be for aircraft weight and balance.
7H4
Mon Mar 05, 2018 8:40 am
I can only give information based on how my airline loads them, but our restrictions on loading is approximately 100 in the front and 120-140 in the rear utilizing all 6 bins (A-F) based on an average weight of 30 Lbs per bag.
Any comments/claims/statements are my own and not those of my employer or anyone else.
commpilot
Mon Mar 05, 2018 10:48 am
I have best I have seen was 243 checked and maxed out cabin overhead bins.
stratclub
Mon Mar 05, 2018 10:58 am
The aft baggage pit tapers down as you go aft from the door. So yup, I could see the aft pit might hold fewer bags than the forward pit.
cotparampguy
Tue Mar 06, 2018 1:39 am
Most I’ve ever managed was 90 in the front, and about 120 aft, but we didn’t use bin F.
kamast
Wed Mar 07, 2018 8:04 am
Thank you very much everybody, so if I understand around 40 bags per bin ?
How many on bin F for instance ?
parmelbe
Fri Mar 09, 2018 6:00 pm
*delete please, sorry*
ALL views and opinions expressed are mine ONLY and are NOT representative of those of Southwest Airlines
7H4
Sun Mar 11, 2018 3:40 pm
Around 30 in A, 15ish in B, 50 in C, 75-80 in D, 15ish in E, and 20ish in F.
arcticcruiser
Mon Mar 12, 2018 2:02 am
Whoa, 6 “bins” in such a small airplane? How many will the MAX 10 have?
7H4
Mon Mar 12, 2018 5:18 am
Same amount. There are three "bins" per door. Bin A is fwd of the front cargo door, B is directly in front and C is between the door and the wing. Bin D is between the rear door and the wing, E is directly in front of the door and F is the furthest rear bin between the door and APU. In the MAX10 bins C and D will be larger (they are the only bins that vary in size for the most part between each model of the NG/MAX).
Acey
Mon Mar 12, 2018 7:12 am
It's not a matter of thinking one is bigger, the rear is objectively bigger. There's no way you're getting 100 in the front unless they're purse sized bags.
