Max Q
Angled nose gear leg
Mon Mar 05, 2018 3:10 am
The DC10, MD11 and A320 series aircraft
are a few types that have a pronounced
‘forward angled’ nose gear
Curious as to why it was designed this way,
there is a disadvantage, in a tight turn the nosewheel on the outside of the turn actually comes off the ground, not good
for steering, especially when its wet
So what were these designers thinking?
Nicoeddf
Re: Angled nose gear leg
Mon Mar 05, 2018 12:49 pm
Edited because of own stupidity.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
fr8mech
Mon Mar 05, 2018 12:57 pm
Nicoeddf wrote:
all of those A/C retract their gear backwards.
None of them retract to the rear.
When seconds count...the authorities are minutes away.
If you want a safe space, go home. If that's not safe, change your home.
Lpbri
Mon Mar 05, 2018 12:59 pm
A320 nose gear retracts forward. DC10/MD11 also.
Nicoeddf
Mon Mar 05, 2018 1:13 pm
Then disregard everything I said! :D Thanks for the correction.
StereoTechque
Mon Mar 05, 2018 7:19 pm
The DC10, MD11 and A320 series aircraft do have the forward tilted NLG gear. It is called Caster Angle.
Link: https://en.wikipedia.org/wiki/Caster_angle
On the above mentioned aircrafts, all have a positive caster angle to maximise straight line stability of the gear. As to why some aircrafts have them and some dont, understand that all aircrafts manoeuvre differently so it is the designers wish. A tight turn on these aircrafts sure lifts up the offside gear but the wheel in contact with ground does its job just fine.
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
CanadianNorth
Tue Mar 06, 2018 1:42 am
Not a designer, so I don't know.
A couple of my guesses though...
- Shorter distance to retract, so shorter/smaller/lighter retract jack?
- One tire off the ground during sharp turns would mean more weight on the tire that remains on, which would actually increase traction on a hard surface and make cornering easier (just like a pickup truck in winter, in two wheel the drive axle tends to fail at traction and spin out on the snow and ice, but throw 100 or 200 pounds of whatever is handy in the box and then the drive axle bites in and it goes just fine again)
- My brain seems to figure at higher speeds such as takeoff and landing having the gear angled forward a bit would actually decrease bending stress on the gear leg. Not sure if I would count that though because the same brain cells also figure that during a hard landing you'd want the gear leg straight up and down while the aircraft is in a typical touchdown attitude to reduce bending forces, which would leave the gear angled back slightly during taxi (on a tricycle gear aircraft of course, taildraggers would be different story).
HS-748, just like a 747 but better!
jetmech
Tue Mar 06, 2018 2:04 am
Exactly, this geometry being similar to the rake and trail of bike steering.
On the B747, A330 / A340 for instance, the nose gear leg is straight up and down.
Self centering in this case is achieved by having the centreline of the axle behind the centreline of the oleo, which provides geometry similar to a shopping trolley castor.
Regards, JetMech
Users browsing this forum: No registered users and 18 guests
