Levan
FADEC2 VS FADEC3 for CFM56 engines
Mon Mar 05, 2018 11:46 am
Hi all,
Would you please give me the explanation what is the difference between FADEC2 and FADEC3 for CFM56 engines?
Thank you.
hitower3
Re: FADEC2 VS FADEC3 for CFM56 engines
Mon Mar 05, 2018 12:23 pm
Dear Levan,
According to http://www.baesystems-ps.com/fadec.php and http://fadecinternational.net/products/fadec-2.php, only the version -7B (as used on 737NG) can have either FADEC2 or FADEC3. I might speculate that there is a typo on the webpage, actually the FADEC 2 is found on the version -3B of the CFM56 which equips the 737 classics, whereas FADEC 3 is intended for use on the 737NG (amongst other aircraft types).
I could not find any information about the differences in regards to design and capabilities between these two FADEC systems.
Hendric
Edit: typo corrected.
Levan
Tue Mar 06, 2018 6:27 am
Dear Hendric,
Thanks for your replay
There is no typo in the web, as far as FADEC2 may be used for -7B engines as well (not only for -3B). Also FADEC2 and FADEC3 may be installed on one aircraft at the same time (for e.g. FADEC2 for LH engine and FADEC3 for RH engine).
Just I was interested what is the exact differences between them.
Levan
hitower3
Wed Mar 07, 2018 7:10 pm
Ok, I stand corrected!
Hendric
lightsaber
Fri Mar 09, 2018 10:51 pm
You have me very curious. All I could find is FADAC 3 can directly process digital signals from sensors. This cuts out a little weight, improves sensor reliability, and allows different types of sensors (not in the CFM-56). I believe it is required for electric actuators in GE engines (does not apply to CFM-56).
I'm sure there are other advantages (processor and memory), but I didn't find details.
http://www.aviationtoday.com/2008/11/01 ... dications/
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
A320FlyGuy
Mon Apr 30, 2018 11:02 am
Lightsaber
You are exactly correct in your assumptions re: FADEC2/3.
My other car is an A320-200
Users browsing this forum: No registered users and 9 guests
