Levan
FADEC2 VS FADEC3 for CFM56 engines
Mon Mar 05, 2018 11:46 am
Hi all,
Would you please give me the explanation what is the difference between FADEC2 and FADEC3 for CFM56 engines?
Thank you.
hitower3
Re: FADEC2 VS FADEC3 for CFM56 engines
Mon Mar 05, 2018 12:23 pm
Dear Levan,
According to http://www.baesystems-ps.com/fadec.php and http://fadecinternational.net/products/fadec-2.php, only the version -7B (as used on 737NG) can have either FADEC2 or FADEC3. I might speculate that there is a typo on the webpage, actually the FADEC 2 is found on the version -3B of the CFM56 which equips the 737 classics, whereas FADEC 3 is intended for use on the 737NG (amongst other aircraft types).
I could not find any information about the differences in regards to design and capabilities between these two FADEC systems.
Hendric
Edit: typo corrected.
Levan
Tue Mar 06, 2018 6:27 am
Dear Hendric,
Thanks for your replay
There is no typo in the web, as far as FADEC2 may be used for -7B engines as well (not only for -3B). Also FADEC2 and FADEC3 may be installed on one aircraft at the same time (for e.g. FADEC2 for LH engine and FADEC3 for RH engine).
Just I was interested what is the exact differences between them.
Levan
hitower3
Wed Mar 07, 2018 7:10 pm
Ok, I stand corrected!
Hendric
lightsaber
Fri Mar 09, 2018 10:51 pm
You have me very curious. All I could find is FADAC 3 can directly process digital signals from sensors. This cuts out a little weight, improves sensor reliability, and allows different types of sensors (not in the CFM-56). I believe it is required for electric actuators in GE engines (does not apply to CFM-56).
I'm sure there are other advantages (processor and memory), but I didn't find details.
http://www.aviationtoday.com/2008/11/01 ... dications/
Lightsaber
You only have the first amendment with the 2nd. If you're not going to offend someone with what you say, you don't have the 1st.
Users browsing this forum: BravoOne, TailDragging and 5 guests
