airboeingbus
Are air stairs an option on the A320 family?
Mon Apr 16, 2018 6:23 pm
The 737 has air stairs which are retractable stairs under the L1 door, I was wondering if this is even an option on the A320? If not would it be technically possible for it to be added? I know ULC airlines like FR use these stairs as it reduces ground equipment costs.
airboeingbus
Re: Are air stairs an option on the A320 family?
Mon Apr 16, 2018 6:33 pm
I’ve just stumbled across a photo of an A319 with them so they are out there! I wonder why it’s not so popular as on the 737Image
keesje
Tue Apr 17, 2018 12:53 am
I guess they are bigger & heavier than on a 737.. adding costs for weight & maintenance.
There are STC's for fitting them on existing aircraft. A costly modification I can imagine. Probably for Business Jets etc.
https://www.modstore.aero/modifications/type(21)/Airbus_A320/modificationId(21263)/Installation%20of%20Aerocon_57_s%20On-Board%20Airstair
"Deploys through existing doors" :eyepopping: I can see a lot of metal in the cabin..
Apparently it has its own cabinet.
https://www.modstore.aero/modifications/modificationid(21250)/Installation%20of%20Aerocon%20Airstairs%20Stowage%20Cabinet
7673mech
Tue Apr 17, 2018 1:56 am
They are an option on the 737.
Most operators opt not to have them.
Also many have removed them.
CCGPV
Tue Apr 17, 2018 2:44 am
I can understand why.
Years ago I climbed one of these on easyjet and even as a young lad it was pretty steep. I remember thinking how rickety they seemed.
Stay curious
Max Q
Tue Apr 17, 2018 2:51 am
I think Ryanair has them installed on their
aircraft
Big advantage when you rarely use jetways
I remember our old 737-200’s had rear stairs installed that stowed in the cabin
Unlike the compact, lightweight forward stairs that stow under the cabin these were
big, heavy and took up a lot of space in the cabin
CCGPV
Tue Apr 17, 2018 2:56 am
aircraft
Very cool. How did that work in an emergency with all that in the way?
Stay curious
Max Q
Tue Apr 17, 2018 2:57 am
aircraft
Max Q
Tue Apr 17, 2018 2:58 am
aircraft
Good question, I think they could be swung or slid to the side
CanadianNorth
Tue Apr 17, 2018 4:12 am
737-100/200 aft airstairs were an option mostly found on combis, where the main deck cargo in the front and passengers in the back would make the forward airstairs basically useless. I've seen photos with them on aircraft without the main deck cargo door but I think that's pretty rare.
The aft airstairs are part of the door, basically like a Dash 8 / ATR / CRJ type set up on steroids. The door is slightly bigger than a normal 737 aft entry door, and it's hinged at the bottom instead of the forward side. The stairs fold into three sections, with the upper third being part of the door and the other two sections stack against that. The door is operated electrically through a switch and a "big Jesus lock lever" which has three positions, closed, open and emergency. In an evacuation just pull it to emergency, give the door a good kick from the inside, and gravity will pull the stair and door assembly into the extended position, and the stairs can then be used to evacuate as there is no escape slide on that door.
In the stowed closed position you do loose some galley space, but otherwise it seems to work surprisingly well considering the weight swinging in the wind and the monkey motion that goes into the extension and retraction.
HS-748, just like a 747 but better!
Max Q
Tue Apr 17, 2018 5:43 am
Very interesting, thanks for that, the whole set up looked very heavy
masi1157
Tue Apr 17, 2018 7:54 am
I don't know if they are still an option, but I do know that the space to install them below door 1 L/H ist still there on all A320 family A/C.
Gruß, masi1157
497 different segments on 98 airlines to 206 airports in 54 countries
Woodreau
Tue Apr 17, 2018 12:50 pm
Gruß, masi1157
I guess an unrelated question. What is the construction is the galley floor between the 319/320/321 L1/R1 doors?
We got a crew bulletin telling us to stop using the galley floor as the primary means of breaking up melted/refrozen blocks of ice that we get sometimes from catering and instead to use the ice mallets. and if we wanted ice mallets our director of operations would personally mail us our own personal ice mallet. The bulletin said the floor structure was taking unnecessary damage from having bags of ice being thrown at the galley floor.
strfyr51
Tue Apr 17, 2018 10:38 pm
The Air-stairs fit into their own container below the L1 door. I've seen them on B737's and A319's alike.
Max Q
Tue Apr 17, 2018 11:38 pm
Woodreau wrote:
Gruß, masi1157
Funny you mention ice being broken up on the galley floor
A few years ago we had blocked in and shut down in EWR on a 764
I was in the RHS at the time just getting ready to leave when I heard a sound like
a bag of ice being thrown on the galley floor
It wasn’t, when I went back to look I saw the L1 door open with the escape slide deployed, next to the door was a very pale looking flight attendant who had not disarmed the door prior to opening it
I think that’s about as career enhancing to a flight attendant as landing with the gear up is for a Pilot
Don’t know why he was opening that door anyway as we were disembarking from L2
I’ll nevet forget that sound though..
Tristarsteve
Wed Apr 18, 2018 11:46 am
The 10 A320 ordered by BCAL and delivered to British Airways had airstairs fitted on delivery from Airbus. They worked in a similar fashion to the B737 stairs, with a separate door under the L1 pax door. If you look closely at any A320 up to about serial 3000, you can see the door cut out blanked out.
I saw these stairs in operation at Toulouse before delivery, but never saw them used in service.
These 10 A320 also had manual toilet service, no vacuum system. There was a service panel just fwd and below this airstair door for the single fwd toilet. This was often forgotten because few rampers knew about it, and it was hidden by the jetty so difficult to access.
DL_Mech
Wed Apr 18, 2018 2:18 pm
The floor panels are a honeycomb composite panel. They can withstand small impact damages, but repeated impacts over time would definitely damage it. Ice hammers are much cheaper than new floor panels.
Notice that the cargo compartment is just below his left hand.
This plane is built to withstand anything... except a bad pilot.
Noshow
Wed Apr 18, 2018 2:22 pm
The A320 floor level sits higher above the tarmac than the lower 737. So climbing higher stairs on the A320 might feel uncomfortable to most passengers. Even on the 737 it seems to be a challenge to some.
Woodreau
Wed Apr 18, 2018 8:00 pm
Thanks very much. That deck is awfully thin... I'm wondering if the space under the galley is just hollow to allow installation of airstairs or have they repurposed the space for other things?
BravoOne
Thu Apr 19, 2018 4:10 pm
I believe PATS made the original after market stairs for a wide range of Boeing airliners and perhaps the AB family as well. I think they sold the STCs for this to another company in the early 2005 time frame. They also made aux tanks for many of the Boeing BBJ family aircraft and perhaps others as well. For a corporate aircraft it was not big deal, but for an airliner it took up valuable space inside. As I recall on the 757 & 767 there was a limit on how much weight could on the stairs at any one time. Watching them extend or retract was like watching a snake uncoil. We were always prepared to unbolt them and let them drop on the ramp if necessary.
masi1157
Thu Apr 19, 2018 7:32 pm
So far they didn't, as I said earlier:
Gruß, masi1157
longhauler
Fri Apr 20, 2018 3:14 am
I remember years ago, flying an A321 from YYZ-SFO and somewhere over the northern states, while sitting back chatting about girls and trucks ... we got an ECAM door warning.
Beside door L1 on the Door page was something that looked like an amber ladder sticking out of the door. Pulling out our manuals (it was a paper era), showed that the stair door was opened! As far as we knew, this aircraft was not equipped with stairs. (It wasn't). In the mean time, our Maintenance Control which also receives our ECAM messages datalinked us and told us not to worry ... it was an anomoly.
No one ever figured out why the warning triggered ... but, apparently it IS an option on some A320 series aircraft to be equipped with stairs!
Users browsing this forum: fr8mech and 9 guests
