Lahso
Wed Jun 07, 2000 9:39 am
Can someone please explain how LAHSO works and the cancellation and acception of LAHSO clearances. Thanks.
Pilot1113
RE: Lahso
Wed Jun 07, 2000 1:53 pm
LAHSO, or Land And Hold Short Operations, occurs commonly at airports with intersecting runways.
When the pilot accepts a LAHSO clearence from the Tower, basically what ATC wants him to do is land and stop before the runway intersection because another aircraft may be taking off or landing.
It is the pilot's responsiblity to accept this clearence.
- Neil Harrison
RE: Lahso
Thu Jun 08, 2000 5:03 am
Interesting that you should bring this up, as it is a hot topic in ALPA.
Everything that Neil said is true. In Canada the terminology is referred to as SIRO (Simultaneous Intersecting Runway Ops).
At the heart of the issue is that the FAA has approved LAHSO to AFM + 1,000 (aircraft flight manual) lading distances. In some cases, this isn't all encompassing enough, and goes against what the FAA and ALPA orginally agreed to.
Okay, so you are monitoring and know that LAHSO may be in effect. When arriving, you simply state your declination as follows: "Tower, Midstate 230 unable LAHSO". To ensure further adequate safety you may also state: "Midstate 230 cannot accept aircraft LAHSO on our runway." Expect a response.
On departing, you should make your intentions as clear as possible and as soon as possible. Do so when you switch up ground. "Ground, Midstate 230 request taxi to the active, unable to take off LAHSO".
aaron atp
Thu Jun 08, 2000 6:04 am
many discussions on the topic have already taken place...
http://www.airliners.net/discussions/general_aviation/search.main?search=lahso
Users browsing this forum: greg85 and 15 guests
