victech
777 Engine Questions
Sun Jun 11, 2000 10:16 am
Hello, I have two question about 777 engines. One, can anyone tell me the average CFM of the engine at cruise? And two, someone told me that at takeoff in semi-humid conditions, the engine will form a cloud from the outer metal rim to the 1st compressor fan. Is that true?
Victor.
dash8
RE: 777 Engine Questions
Sun Jun 18, 2000 12:18 pm
1. Don't know what CFM means.
2. It's true. Caused by accelerating airstream. Faster stream means reduced local pressure. Which means colder temperature, which means a lower dewpoint (temperature at which water in gas state condenses to fluid). Because of this excess water vapour in the air will become visible as a greyish cloud.
p.s. If at No1 you mean fuel consumption?
It's about 15,000 pound per hour.
dnalor
Sun Jun 18, 2000 7:33 pm
Wonder if he means Cubic Feet per Minute, the way induction systems are rated in cars.
victech
Sun Jun 18, 2000 8:23 pm
Dash8, thanks for the clarification on the cloud question, I guess I'm not remembering my physical science classes as well as I should. As to CFM, yes, I was asking for how many Cubic Feet per Minute the engine "sucks in" while at cruise.
Thanks.
TOP
Mon Jun 19, 2000 1:55 am
Hello Victech,
the (max.) air mass flow of the PW4098 is about 1270 kg/s.
Stephan
Duisburg,
GERMANY
victech
Mon Jun 19, 2000 10:21 am
Thanks for that info, now if I remember correctly, one cubic meter of air is 1.3kg. Therefore, that's about 983 cublic meters per minute; so about 34,714 CFM or 259,758 GPM of air. Please correct my math if it is off.
TOP
Tue Jun 20, 2000 12:25 am
These values are per second and not per minute!
Stephan
Duisburg,
GERMANY
victech
Tue Jun 20, 2000 2:54 am
Woops! In that case, that's 2,082,840 CFM - which is, wow, a heck of a lot of air. But on the other hand, only about 25-30% of that will ever see the combuster.
TOP
Tue Jun 20, 2000 4:23 am
To be precise, only 17% of the whole air goes to the combustion chamber (PW4098).
PW4084: ~15%
More interesting data you can find here:
http://www.boeing.com/assocproducts/aircompat
