Holding Speed
Sat Jul 22, 2000 2:53 pm
Hello. Can someone tell me the speed limits for holding at certain altitudes? Thanks.
oecmr
RE: Holding Speed
Sat Jul 22, 2000 9:21 pm
to 14.000ft MSL.... 240Kt
from 14.000ft to 33.000ft.... 265Kt
from 33.000ft.... Mach 0.83
RE: Holding Speed
Sat Jul 22, 2000 9:23 pm
From what i know it is relative to the particular regulations of the country.
Aust Regulations state the following: these are ICAO compliant as far as i KNOW so regs around the world should not vary too much.
ENR 1.5 para 3.2
Unless otherwise specified, holding procedures are subject to the following limitations:
a speed: IAS must no exceed
1) up to and including FL140
-230 kt, or
-170kt for holding, limited to Cat A & B aircraft only;
2) above FL140 up to and including FL200, 240kt; and
3) above FL200, 265kt.
Note: above the highest MSA in turbulent conditions, speeds may be increased to the lesser of 280kt or M0.8 subject to ATC aproval in CTA.
AAR90
RE: Holding Speed
Sat Jul 22, 2000 11:31 pm
In the USA, for turbojet aircraft:
Altitude Range / Max Speed
0000 - 6,000 ft / 200kias
6,001 - 14,000 ft / 230kias
14,001 - above / 265kias
Users browsing this forum: gloom, Starlionblue and 1 guest
