modesto2
Tracon
Thu Aug 17, 2000 1:37 am
Terminal Radar Approach CONtrol...what does it do? Is it as simple as "approach"? Anyone who can provide ANY information about TRACONs - please respond! Thanks.
RE: Tracon
Thu Aug 17, 2000 3:47 am
I'm no expert on the topic...What I know is that TRACON refers to one of many FAA ATC facilities that provide traffic control in the terminal areas using radar. This type of service typically is near airports with altitude from the ground to about 15,000 ft.
Check this web site out for more info (maybe  )
http://www.faa.gov/ats/
Nut
Pacific
RE: Tracon
Thu Aug 17, 2000 1:09 pm
The TRACON at New York controls the whole airspace outside the vicinity of the airports. They line up the planes for approach before the plane passes to the approach control at the airport. They generally just organise the traffic outside the controlled area of the airports. Hope this helps.
JETPILOT
RE: Tracon
Thu Aug 17, 2000 2:10 pm
The TRACON is approach control.
On arrival you are handed off from Center to Approach control which hands you off to Tower.
TRACONS control Class B airspace.
RE: Tracon
Fri Aug 18, 2000 5:53 am
TRACONs don't nessesarily just do Class B airspace, all your class C airspce would also have a TRACON. Basically TRACON is just the name for the building, it provides approach and departure services for an area. Often there will be smaller satalite airports under the TRACONs airspace, and they'll do the same for them. At your larger TRACONs like the NY TRACON, N90, the area will be broken down into smaller sectors, and divided up by airports as well. So you may just be the "final" controller for EWR or LGA...etc.. Controllers at these places cycle through the different sectors and between approach and departure (which may be combined at some places)
RE: Tracon
Sat Aug 19, 2000 3:51 am
Greetings:
There is a great simulator called TRACON and one called RAPCON (Radar Approach Control) for military operations,
which can be purchased for about $25 each. The software is a spinoff of training software for air traffic controllers (ATC). The workload can be varied and pilot errors and weather movement is also simulated. A scoring is maintained and various Mayday and missed approaches are included. All pilots should try this software to get a feel for the workload and problems faced by ATC people. The software has Seattle, Boston Los Angeles and several other commercial and military centers (Edwards AFB, Miramar NAS). I have our engineers working on freeflight ATC work with these programs so that they can get a feel for the real world problems.
Apopa
