pmk
Runway Regulations
Thu Sep 07, 2000 6:43 am
This may not belong here but I'll try it.
What are the rules on building an airstrip?
The reason I ask is that my family owns a lot of "bush" type property in West Virginia. If I wanted to build a runway (tarmac, lights, the works) would I have to consult the FAA? If so what would be involved?
Thanks in advance
Peter
RE: Runway Regulations
Thu Sep 07, 2000 6:50 am
I do not believe there is any FAA involvement when a 'Restricted' airfield, that is one that is not open to the public, is built. It does, though, have to be registered with the FAA. I am sure you should consult the FARs thoroughly before you start any big plans, though.
Ralgha
Thu Sep 07, 2000 11:02 pm
Why build a runway? Landing on turf is much more entertaining
Fri Sep 08, 2000 12:31 am
You can go ahead and build whatever you want. Maybe the only government involvement may be local. Other than that you can open a private airstrip. It would show up on the sectional for that area, since, theoretically, anyone could land there (in an emergency). But there's no recomendations on length, width, lights. You be surprised and maybe a little frightened by some of the private strips that are out there.
Greg
pmk
RE: Ralgha
Fri Sep 08, 2000 3:59 am
Birds land on dirt, aircraft land on tarmac!!
Peter
sccutler
BYO Runway
Fri Sep 08, 2000 9:03 am
I have friend who just finished constructing a runway at his little ranch; plenty of land, adequately situated (slight prevailing crosswind), built with drainage and a very nice hangar.
Last week came first time to land there; he overflew it several times, noted that those trees on the approach end that looked so far away when on the ground, looked mighty close on approach. Finally set up his landing as best he could, touched down "before the windsock," so he stood on the brakes; stopped with about 100' rwy remaining.
The chainsaw has been active since!
He told me, "You know how when you solo, they cut off your shirt tail to put on a plaque? After that landing, I tacked my soiled drawers up on the hangar wall!
...three miles from BRONS, clear for the ILS one five approach...
L-188
Fri Sep 08, 2000 5:00 pm
Your big problems aren't going to be with the FAA. It is going to be with your local zoning board and your neighbors.
It also (unfortunatly) to hear about somebody who has had a personal airport for years getting a new neighbor and the newbie suing the airstrip owner claiming it was a safety hazard. I think that is bull but a lot of courts haven't agreed with me.
I don't know if AOPA or any of the other alphabet groups have any info out there.
As far as pavement goes. It is nice but it isn't all that it is cracked up to be. Grass is prettier and smell better when it is cut
Mon Sep 11, 2000 5:30 pm
I know this subject hasn't been accessed for a few days but, seeing as designing runways is what i do for a living i couldn't resist the opportunity to join in.
From a construction point of view, whether you intend to have a paved or an unpaved airstrip you need to know what the ground conditions are like. You don't want to spend lots of money profiling the ground and setting up, only to find there's a soft spot about 1 metre down that sinks every time you land on it (the reason you don't tend to hear about catastrophic runway suraface collapses occuring is because airfield designers are so paranoid about the idea we make sure that it won't happen). Any local Site Investigation company should be able to do the work and give you some meaningful results and advise for a reasonable sum (make sure they give you advise about how the conditions will change between wet & dry weather). If you intend to install some form of lighting, either now or in the future, you will probably also need to check with the FAA or local aerospace bodies; i don't know about America but in Britain and Europe there is strict licensing on airfield lighting to prevent small airfields causing confusion to other traffic, especially in night time emergencies when a pilot may be looking for the nearest usable airfield.
Users browsing this forum: 747classic, Okcflyer and 25 guests
