AFa340-300E
CX A340 Dolphin Skin
Sun Oct 01, 2000 8:43 pm
Hello,
I had read an article over two years ago about the test Cathay Pacific made on one of its A340-300Es with some dolphin skin on its wings, which were due to reduce drag. Thiswould result in 1 ton fuel economy on a "typical long-haul flight" (I know this is close to no meaning without the exact sector on a period pf the years in certain conditoins).
Anyone would have some information about this please?
Were the test successful?
What precise aircraft get these skins?
When was it made please?
Thank you,
Alain Mengus
RE: CX A340 Dolphin Skin
Mon Oct 02, 2000 5:33 am
you are right about the special skin, It was a success by reducing the total drag that the aircraft produced. Rather then the skin being smooth, it was covered in platelets like a Dolphin giving less drag. But the cost to fit an aircraft with ths special type skin was so much that they believe an airline would not bear the cost over fuel saving.
The Discovery channel ran a documentry on it some time a go. IF I can find some more infomation i'll let you know.
L-188
Mon Oct 02, 2000 9:00 am
The tricky part with those type of skins is keeping the pores clean and free of dirt and grime. This type of technology has been used for years on racing sailboats.
Flipper must be relived. How many dolphins do you have to skin to cover an A
AFa340-300E
Tue Oct 03, 2000 3:39 am
Hello,
Any idea of the price?
If they have let the skin on the A340? If not why they removed it?
Thank you,
Alain Mengus
Tue Oct 03, 2000 4:58 am
I hope no tuna were hurt in this experiment.
Thu Oct 05, 2000 4:52 am
have found some more info on the skin, it was a special paint which contained tiny beads, will let you know, soon as I get more info.
Minuteman
Sat Oct 07, 2000 10:08 pm
I had an opportunity to work with some scraps of material similar to this
It was made by 3M for Airbus and went for about $10,000 per sq/yd (?)...EXTREMELY expensive, but it was a rivulet-covered film that was applied to the upper surface of the wing in an attempt keep the boundary layer attached. It was basically like a micro-scale corduroy (sp?) texture.
Users browsing this forum: conflats, TailDragging, yycdel and 16 guests
