G-KIRAN
Parallel Runways
Sat Oct 07, 2000 11:43 pm
Does anyone do the minimum distance between 2 parallel runways so that they can be used at the same time?
AFa340-300E
750m Max
Sun Oct 08, 2000 12:56 am
Hello,
I know that parallels runways are at maximum 750m far one from the other to be considered as parallels.
Alain Mengus
mcomess
RE: Parallel Runways
Sun Oct 08, 2000 12:52 pm
In order to operate simultaneous operations (two aircraft landing at the same time), you need 4300 feet inbetween the centerlines of your parrellel runways.
timz
Mon Oct 09, 2000 8:53 am
The 4300-ft rule (US only?) refers to simultaneous independent instrument landings. If ATC keeps the aircraft staggered (i.e. not alongside each other) ILS approaches can be flown to closer parallel runways, and of course in clear weather airliners land side-by-side on SFO's runways 28L/R, which are 750 ft center to center. The legal minimum is maybe 700 ft (?).
Mon Oct 09, 2000 11:58 am
At SNA the runways are quite close together between each hold short bar there is barely enough room for a 757. So I would guess it is about 200 feet. With 19L being 75 feet and 19R 150 feet, that makes them very close together.
Iain
timz
SNA
Mon Oct 09, 2000 1:29 pm
If we can believe the lats and lons on www.airnav.com then SNA's two runways are 500 to 501 ft apart, center to center.
Mon Oct 09, 2000 9:21 pm
What about FRA? as far as I know they cannot use their runways simultaneously for landings. Hopw far are they apart?
Tue Oct 10, 2000 3:09 am
We land on both of them all the time but they can not do dual ILS approaches, which requires more room.
Iain
Users browsing this forum: AT72 and 1 guest
