757 Wheel Coast
Mon Oct 23, 2000 7:59 am
While on a flight last week on a DL 757-200, the 2nd officer came on the intercom shortly after takeoff and announced that it would be necessary to allow the wheels to come to a stop without the use of wheel brakes before they could be stowed. He made us aware of this since the time the geer was retracted was unusually long. Anyone know why they chose to do this?
RE: 757 Wheel Coast
Mon Oct 23, 2000 9:56 am
Sounds like they had a brake deactivated.
Normally the main gear wheels are braked automatically when the landing gear handle is raised. If they weren't, gyroscopic principle (like holding a spinning bicycle tire in your hand and moving it around) would cause undo stress on the gear as it's retracted.
If a brake had been deactivated the crew would have to leave the gear down for a couple of minutes after T/O to allow the wheel to spin down on it's own.
sk902hvy
RE: 757 Wheel Coast
Mon Oct 23, 2000 10:06 am
How much drag would the lowered gear create and would there be a speed restriction on climb out?
sk902hvy
AAR90
RE: 757 Wheel Coast
Mon Oct 23, 2000 10:08 am
Probably just hot brakes. Many new 757 captains have a tendency to "ride the brakes" to keep taxi speeds lower on lightly loaded aircraft. Probably noticed the brake temp as they reached for the gear handle which is probably why the PA was done after takeoff instead of before takeoff.
Just a guess though. It could also have been some missing rub strips in the wheel well(s). Rub strips rub against the tires to stop their rotation after gear is up and in the wells. Not that uncommon, but every time I've experienced this the captain made a PA prior to takeoff.
RE: 757 Wheel Coast
Mon Oct 23, 2000 10:48 am
Thanks it all now makes sense. As to the climb rate etc with the geer down, as overpowered as the '57 is I didn't notice anything unusual. Just a bit more engine noise than normal with the wheels down.
AAR90
RE: 757 Wheel Coast
Mon Oct 23, 2000 11:18 am
Lots and lots of drag.
270 knots indicated speed limit for gear in transit.
RE: 757 Wheel Coast
Mon Oct 23, 2000 10:22 pm
What happened is not all that uncommon. I would suspect that the most likely cause was hot brakes, as AAR-90 pointed out. Also, depending on the aircraft's ground turn time and SLC air temps, the brakes may have been hot already and didn't get sufficient time to cool.
Just to give an idea of the speed restrictions regarding the landing gear for an aircraft Other than the 757:
The max speed on the DC-9 to extend the gear is 300kts
The retract speed is 250kts in our manual.
The max tire speed is 195 kts.
On airlines that operate jets on multiple hops to short fields, they often extend the gear for an extended period of time to cool the brakes. An example is Air Mike's 727s--lots of short hops to small island airstrips where this happens a lot.
Users browsing this forum: celestar345, VolvoBus and 19 guests
