archie
A Question To Airline Pilots
Mon Oct 23, 2000 12:23 pm
Hi,
I have heard people say that they have talked to pilots who fly Airbuses and have heard them complain about the joystick. My question goes to pilots who have flown airbuses.. Is it realy a bad thing or is it the same a conventional yoke?
Archie
RE: A Question To Airline Pilots
Mon Oct 23, 2000 12:43 pm
From all the pilots I have meet which have flown both Airbus and Boeing, the like the space that the side stick provides, and they say they get used to it very quickly. Also the F-16 has a side stick!
Iain
Gate Keeper
Mon Oct 23, 2000 10:53 pm
The joystick took me about 5 seconds to get used to. The beauty of this aircraft is if the engine fails at take-off you set the pitch attitude then you can let the stick go(autotrim). Conventional aircraft this is not possible. I have flown both Boeing and Airbus and they both have their own (dis)advantages.
GateKeeper
archie
Tue Oct 24, 2000 4:42 am
GateKeeper,
What airline do you work for if I may ask?
What do you like about each aircraft and what don´t you like of each?
Thanks for your reply,
Archie
Kohflot
Tue Oct 24, 2000 6:40 am
I intentionally ask every crew I jumpseat with on the A319/20 how they like the sidestick and all of them have given positive feedback. Since the vast majority of flying these days is done with the autopilot anyway, it does provide a lot more room for the traytable and the folding footrests.
Most crews did have one little bone to pick with the planes.. they really don't like to slow down.
Ask why..
prebennorholm
Tue Oct 24, 2000 7:54 am
A friend of mine used to be a long time 737 driver, but he converted to 320 a couple of years back. He told me that the Joystick/yoke was really one of the minor changes.
I asked him directly why they didn't put skipper's joystick in the right hand too - it is quite a change to shift from right to left hand I assumed. We are both keen model aircraft enthusiasts, and I would certainly crash my models immediately if my radio transmitter constol sticks were exchanged left and right. He said "no problem". He had flown the sim in the left hand seat and hardly discovered any difference. Apart from model airplanes the 320 is a single stick plane. The computer operates the rudder - except for touch down in sidewind - and keeps the ball automatically in the middle. So the 320 is - as he said - as easy to fly as any basic trainer model aircraft. It is only more costly to crash.
It was an advantage, he said, to have that joystick put away always to the far side, so it wasn't in the way. Holding the stick was such a small part of the total workload. Anyway skipper also flies the yoke with his left hand and his right hand on the throttles.
Best regards, Preben Norholm
Gate Keeper
Tue Oct 24, 2000 10:45 pm
Archie,
I miss the excess power of the Boeing(757) and the hands on flying. The Airbus is a technological marvel and complex machine that I am continually trying to know better. To hand fly the Airbus (other than on approach and departure) loads up the pilot not flying due to the number of Flight Control Unit inputs.
Best regards
GateKeeper
archie
Wed Oct 25, 2000 4:49 am
GateKeeper,
Thanks. I want to be a pilot my self one day I am working to save my money for a flight school. One of my goals is to fly both Boeing and Airbus aircraft, That`s why I`m interested in hearing pilot`s opinions on both aircraft.
Personally, which do you prefer, the Boeing or Airbus and Why?
Thanks again,
Archie
I would like to hear othe pilot`s opinions too!
Wed Oct 25, 2000 11:34 pm
Gate Keeper,Archie,
Like you GK,I have flown airplanes from both builders and then some more.
Generally,people get the knack of the side stick in about 20 seconds flat.The only off-putting feature being a sense of "feeling naked" in front of the instrument panel as there is nothing where you were so used to expect a control column.
The sidestick allows smooth and accurate control of the aircraft in all situations,the main impression is "this is so easy and so safe"
Another plus that has never been talked of in these pages is how lighter the stick is when you want to take over the autopilot.To illustrtate this,let me tell the experience of a colleague of mine :
He was descending on autopilot when passing 10,000 ft the F/o shouted "Glider straight ahead!"
The capt just banged the stick to his right,disconnecting the A/P and banking the 320 to more than 50 degrees in less than a second.They barely missed the glider,just clipping half an inch off its rudder.The glider pilots never saw them and did'nt even know about their rudder until the police came to investigate a near-miss.
When I think of the effort needed to overpower the A/P -or to disconnect it and then bank the airplane-and to achieve the same bank angle,I do not believe any -and I mean ANY- other airplane would have made it so easily.
To comment on GK's last comment,hand flying any modern airplane puts a heavier workload on the other pilot.It is the main drawback of a two-man-crew operation,regardless of the airplane manufacturer.
Regards.
archie
Thu Oct 26, 2000 4:24 am
Skyhooked,
Thanks for your comments. They are helpfull in understanding the A320`s capacities. I have heard that the 777 is also very easy to disconnect the autopilot, I don´t know which is easier. I have two videos one about the 777 and one about the A330 both from ITVV videos in the U.K.
The video on the 777 shows how easy is to disconnct the A/P, same as the A330 (pressing a button on the control column/sidestick).
Any more comments are welcome,
Archie
Thu Oct 26, 2000 5:28 am
Archie
Disconnecting the A/P in this case is only half the story because now you need to use the control wheel to bank the aircraft.As is is quite heavy,because of the need to provide a "feel" to the pilot (The faster you go,the heavier the controls should feel),to achieve the roll rate I was referring to in my previous post,IMO,would be quite difficult,needing a very aggressive input on the wheel.Mind you,I did'nt say impossible.
archie
Thu Oct 26, 2000 1:06 pm
Hello Skyhooked,
Thanks for the info. I want to know if you don´t have the "force" feeling with the sidestick as in the control column. If not wouldn´t there be a danger of "over rolling the aircraft" or something of that sort?
Archie
MD80
Thu Oct 26, 2000 11:58 pm
I was watching a show on TV about the 777 and a comparison of its computer and the A320 was made. Apparently the A320's flight guidance computer will not allow a pilot to to "roll" the craft no matter how much input he gives the stick while the 777's computer will make the yoke progressively more difficult to turn the more the plane banks but will not override the pilot and the pilot could roll the craft (God only knows why he'd want to?).
Dedicated for the MD-80, MD-90, MD-95 ehhh...Boeing 717, and DC-9: http://www.MD-80.com
Gate Keeper
Fri Oct 27, 2000 12:08 am
Archie,
The Airbus has a "cocoon" of safety around it that prevents the aircraft from exceeding manufacturers prescribed limits. The scenario you suggest could not happen in the Airbus (in normal law) as the aircraft pitch protections would limit the available bank to 67 degrees which corresponds to the bank angle needed for a level 2.5g turn.
Hope this helps!
GK
Fri Oct 27, 2000 2:49 am
Archie,
Yes.The roll protection is 67 degrees in the "normal" flight enveloppe.The allowed bank angle goes down to 45° if either the high incidence protection or the high speed protection are activated.
When the roll protection is activated,auto trim becomes inoperative and if the bank angle exceeds 45°,the flight director command bars disappear,knowing that the pilot wants a maneuver outside the normal ops,therefore removing a conflicting info :"Oh,you want some drastic bank angle?Ok!go ahead,I'm out of it,I'll come back when you need me again!,when you return to less than 45°."
MD-80,
As I said in a previous post,this is just not true.Another red herring for aviation illiterates.
Suppose the autopilot is on and you want to take over in an emergency.OK?
-On the 'Bus,you need 3.5 kg on the stick to disconnect the A/P and you could achieve quickly a very high roll rate,around 15°/s up to 67° with no subsequent effort.
-On any other airplane,you have to disconnect the A/P with the yoke button and then muscle the wheel (as you noted,the required force increases with the roll demand ,around 25 kg max ).
To add, imho, some more confusion,on some types a voice will start yelling "Bank angle,bank angle " in your ears.I know that many people like it that way and I certainly do not want to start an argument on this subject.Let's just say I hope my info and Gate Keeper's helped you understand a bit of the 'Bus flight controls.
Regards to all,
Roland.
archie
Fri Oct 27, 2000 4:20 am
Just let me get somethig straight. To disconnect the A/P on the Airbus you only need to move the sidestick? and on other airplane like the 777 you have to diconnect it with the button on the yoke?
Do I have this right?
Archie
Fri Oct 27, 2000 4:31 am
Dear Archie
No.On all airplanes,you can disconnect the A/P by:
1-Pressing the A/P disconnect switch o the control column or:
2-Using the eye-brow panel disconnect switches/pallets or :
3-Overpowering the A/P with a sidestick/control column manual input.It's a lot heavier on a non'Bus a/C.
Roland
fr8tdog
Fri Oct 27, 2000 5:04 am
I can only give specific info on the SaaB 340, however it will probably pretty close to most transport aircraft.
5 ways to disconnect the autopilot.
1.) Autopilot disconnect (press twice to disconnect and disable warning)
2.) Trim switches.
3.) Manually turn off autopilot
4.) Goaround mode (on the saab,autopilot is not avail for goaround mode, have to reengage after selected)
5.) force the yolk (it disconnects after 50lbs of pressure)
other ways that it will disconnect are:
malfunctions, aileron trim excessive for turn rate, elevator trim excessive. Stall warnings, less than 1.3Vso in turn, FD failure ect.
archie
Fri Oct 27, 2000 5:20 am
Skyhooked,
What´s the eye-brow panel?
Archie
Users browsing this forum: ordpia and 5 guests
