9A-CRO
Crew
Antonov An-72 Engines Question
Sat Nov 04, 2000 12:09 am
why does AN-72 have over the wing mounted engines
is it for increasing lift?
and if so, why isn't this concept applied to any other aircraft in service?
Click for large version
Photo © Tomislav Muic
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward...
christianbothe
RE: Antonov An-72 Engines Question
Sat Nov 04, 2000 2:54 am
Yes,
the stream of hot exhaust gases on the upper side of the wing causes an increased lift (the so-called Conda Effect). Besides the chances of FOD is lower, so it can be used on primitive airstrips. But it is harder to maintain and check the engines.
  christian
L-188
Sat Nov 04, 2000 8:08 pm
The only other aircraft I have seen with this engine setup was the Boeing YC-14. It is on display at the Pima Air museum.
I don't know which aircraft was first.
Users browsing this forum: Baidu [Spider], FBWFTW and 1 guest
