Rotate777
Prescision Approach Path Indicator
Mon Nov 27, 2000 1:08 pm
What are the prescision approach path indicators (PAPI lights) on the runway for? Thanks.
RE: Prescision Approach Path Indicator
Mon Nov 27, 2000 2:06 pm
It gives visual guide to whether you are on glideslope, above or below it.
dknhawkins
Tue Nov 28, 2000 5:22 am
When talking about PAPI's there are to types a 2 and 4 light system. Busyier airports use 4 light PAPI'S. It is used to fine tune your approach better than a VASI. 2 red 2 white your on the glide path, if your a little high you will see 3 white a 1 red, if your a little low you will see 3 red and 1 white. VASI'S do not have that feature. It only shows high, low or on the glide path. Its up to the pilot to determine how high or how low he/she is. Hope that helps.
Hawk
azeem
Tue Nov 28, 2000 5:03 pm
They are your decision guide for adjusting your descent rate. In order to match the PAPI, you have to get 2 red and 2 whites...or 'red over white..you are all right'....and 'red over red....you arfe dead'. Anotehr sert of lights are VASI 'Visuakl Approach Slope Indicator'.
Ralgha
Tue Nov 28, 2000 6:48 pm
PAPI and VASI are different things, PAPI is 4 lights in a row, red and white depending on your position relative to the glidepath, I won't define which means what since people have already done that.
VASI consists of light bars, up to as many as 3 rows, possibly on both sides of the runway. With the 3 row systems, you go by the upper two rows if you're in a high-cockpit aircraft, and the lower two if you're not.
Ralgha
Addendum
Tue Nov 28, 2000 7:07 pm
After posting my last post I was unsatisfied with it sooooooo, here goes.
VASI (Visual Approach Slope Indicator): Consists of horizontal bars, one above the other (or a column of 3)
Using 2:
Both are red, you are below the glidepath
Top is red and bottom is white, you are on the glidepath,
Both are white, you are above.
Using 3:
If all are red, you are below both glidepaths
Top two are red, you are on lower glidepath
Only the top is red, you are on the upper glidepath
All are white, you are above both glidepaths.
PAPI (Precision Approach Path Indicator):
Lights arranged in a row, four across.
All white, you are high (generally more than 3.5 degree descent path).
Far right red, you are slightly high (generally 3.2 degree path)
Right two red, you are on the path (generally 3 degree path)
Right three red, you are slightly low (generally 2.8 degree descent path)
All red, you are low (generally less than 2.5 degree descent path)
PVASI (Pulsating Visual Approach Slope Indicator):
Single light unit that projects two colors, red and white, into the final approach path.
Pulsating White: Above glidepath
Steady White: On glidepath
Steady Red: Slightly below glidepath
Pulsating Red: Below glidepath
Tri-Color:
Single light unit that projects a three-color beam into the approach area.
If you see
Amber: You are above the glidepath
Green: You are on the glidepath
Red: You are below the glidepath
If you are only slightly below the glidepath you may see a dark amber.
Some runways have three painted plywood panels, usually black and white, or some high vis. color. They would be arranged in such a way so that:
If you are above the glidepath, the center panel appears to be above the other two
On the glidepath: the panels appear to be in a straight line
Below: the center panel appears to be below the other two
Users browsing this forum: Exabot [Bot] and 2 guests
