Pressurization
Fri Dec 08, 2000 12:39 am
I want to know weather a 747-400 cargo section is pressurised or not.
JT8DJET
RE: Pressurization
Fri Dec 08, 2000 12:51 am
Yes, it is.
VirginFlyer
RE: Pressurization
Wed Dec 13, 2000 5:30 pm
It has to be. When an aircraft is pessurised, the pressure has to be even, or compensated for by strong matterial. This is why aircraft are basically cylindrical, with pressure bulkheads at either end. If the underfloor hold was not pressurised, the floor would need to be very strong to cope with the load placed on it by internal air pressure.
A practical example of what happens when this situation is suddenly changed is the THY DC-10 crash in Paris in the '70s. The cargo door was incorrectly designed. As the aircraft was climbing, it blew out. The underfloor hold instantly depressurised, but the passanger section had no way to do so, meaning there was a very sudden and rather high pressure differential between the area above the floor and under it. As a result, the rear cabin floor collapsed into the hold and fell out the back of the aircraft, taking many passangers withit. This also severed all the control cables, and the aircraft entered a dive and crashed, killing all on board.
"So powerful is the light of unity that it can illuminate the whole earth." - Bahá'u'lláh
dc10hound
RE: Pressurization
Sat Dec 16, 2000 3:20 am
I certainly hope it is. Big Problem if not....
"Eagles soar. But weasels never get sucked into jet intakes.."
