Frangible Fitting
Fri Jan 05, 2001 10:30 pm
Can Anyone explain the working of the Frangible Fitting located in the Wheel well of B737NGs.
regds
HAWK
VC-10
RE: Frangible Fitting
Sat Jan 06, 2001 5:30 am
The frangable fitting is there to prevent the rear spar being ripped open in an accident. The fitting will fail first and thus prevent a fuel spill.
Sat Jan 06, 2001 5:12 pm
How does it work.
regds
HAWK.
VC-10
Sat Jan 06, 2001 6:02 pm
It just a designed weak point in the structure that breaks at a predetermined load
milo
Sat Jan 06, 2001 9:00 pm
VC-10 i am not sure you ansvered this one corect.
"The frangible fitting removes up pressure from the main landing gear actuator when a dameged, spinning tire moves into the main gear wheel well. This prevents damage to compenents in the wheel well."
this was taken directly out of a 737 book
it is just a small fitting installed right besides where the wheel moves into the wheel well. the fitting is conected to the up presure line to the main gear actuater, and if a spinning dameged tire hits it, it will bleed the press to the actuator and a fuse will close, and the gear will stay down.
MILO
Sat Jan 06, 2001 9:56 pm
So the purpose of the Fitting is to Avoid a tire burst in the wheelwell creating additional damage.Right.
regds
HAWK.
milo
Sun Jan 07, 2001 10:27 pm
The purbose is to awoid a burst tire entering the wheel well and creating additional damage.
That is corect.
MILO
Mon Jan 08, 2001 4:27 pm
Why were the Tire burst screens removed.The Earlier Aircrafts had them.
regds.
HAWK.
milo
Mon Jan 08, 2001 7:34 pm
That one i can not help you with, i have never been near an older 737.
MILO.
Users browsing this forum: Bing [Bot], StereoTechque and 2 guests
