A319/320 Over Wing Slide
Sat Jan 06, 2001 10:37 am
has anyone experienced a deployment of an overwing slide on the 319/320 airbus during a deicing event?
widebody
RE: A319/320 Over Wing Slide
Sat Jan 06, 2001 1:55 pm
Under what circumstances?
Sat Jan 06, 2001 2:04 pm
possible direct spray to hatch -7 degrees air temp with type one fluid @180 degrees.
widebody
Sat Jan 06, 2001 11:20 pm
Never heard of anything like that...was working with AIB for 8 months in emergency evacuation, and never came across a scenario like that.....that's not to say old cases exist......
A320FO
Sun Jan 07, 2001 2:07 am
Sorry, never had it / heard of it
A320FO
aca320
Fri Jan 12, 2001 1:39 am
Here at Air can we do a deploy test of the odd overwing slide (don't do it very often its hell getting the slide folded back ) to check emergency lighting and slide deployment. There is an inspection card for inspecting the cover panel looking for delam and erosion of the panel this is due to a couple slides having lost in the past but nothing recently they do say in the AMM for the 320 that when doing deicing of the A/C not to spray directly at the cover panel. I will say this though that the 767 has had a history of lossing overwing slides and it still is a problem.
widebody
Fri Jan 12, 2001 5:00 am
ACA320, when you mean losing, do you mean failed deployments or actually inflight loss?
RGDS....
Users browsing this forum: atalanta89 and 19 guests
