pmk
Would A Safire S-26 Need A GPU
Sat Jan 27, 2001 1:56 am
Just a quick question:
Rather than me calling Safire and asking, does anybody here think a Safire S-26 would require a GPU to start the engines? I can't see an A/C that small having an APU, so how do the engines start? If you need reference please look at http://www.safireaircraft.com.
Peter
crjmech
RE: Would A Safire S-26 Need A GPU
Sat Jan 27, 2001 2:19 am
My guess would be that electric starters would be fitted, perhaps even starter/generators. An APU adds alot of weight and complexity, something that the designers seem to want to avoid. A GPU could be used to provide electrical power to start the engines or, providing they have enough juice, the aircraft's own batteries.
Thou shalt mind thine altitude,lest the ground reach up and smite thee.
Sat Jan 27, 2001 6:20 am
You'll probably start the engines with battery power but I think you would want the GPU for electrical power for preflight etc. Turbine engines are expensive and I doubt you would want to burn time just for electrics.
L-188
Sat Jan 27, 2001 6:34 am
Probably would be a starter/generaltor combination using a 24VDC ground plug in.
Users browsing this forum: boeing767322er and 19 guests
