chopper
Critical Airflow Sensor?
Sun Jan 28, 2001 1:01 am
what is a critical air flow sensor refering to the 737
NKP S2
RE: Critical Airflow Sensor?
Sun Jan 28, 2001 1:37 am
It's really the angle of attack vane. It just says "critical airflow sensor" on a stencil near it to warn people not to touch or damage it. It is basically a potentiometer that has a vane that moves as the aircraft's angle of attack changes...the vane stays paralell to the relative forward motion of the airplane...and so as the plane's pitch changes, the vane and potentiometer tells the Air Data computers this info.--- It is primarily used for stall protection. If the vane moves past a certain point the flight crew will get a "stall warning" warning...accompanied by an intentionally irritating buzzer, and the "stick shakers" vibrate the control columns as an added warning. --- The stencil is there because it's VERY sensitive and is easily damaged by jetways, ham-fisted ground personnel etc. It is also electrically heated to prevent it from icing up and if you touch it it will burn your hand so fast that it'll kill the nerves on your fingertips....You'll smell your skin burn before you feel the pain--Trust me Smile
NKP S2
RE: Critical Airflow Sensor? Addendum
Sun Jan 28, 2001 1:45 am
It should be noted that there are two AOA vanes...one for the pilot, the other for the co-pilot. There are also several Pitot tubes in the area: They're primarily for measuring airspeed, although some have a static orifice as well.
Users browsing this forum: JJV and 1 guest
