Odals Approach Lights
Sun Jan 28, 2001 5:30 pm
Can someone tell me what they look like from the pilots perspective and how are they diffrent from REIL lights, thanks.
Ralgha
RE: Odals Approach Lights
Sun Jan 28, 2001 8:37 pm
REIL consists of sequenced flashing white lights, one at each corner of the threshold
ODALS consist of omnidirectional flashing white lights, one at each corner of the threshold, and also a line of them extending out to 1500' from the threshold.
I haven't actually seen ODALS at any airports I've flown into, but I can tell you that they probably look like a string of flashing white lights  Big thumbs up
Buff
Mon Jan 29, 2001 9:23 am
Old nickname: Running Rabbits, because of sequence of flashing from furthermost point away from the runway back to the runway threshold.
Best Regards,
Buff
Ralgha
Mon Jan 29, 2001 9:29 am
Not to start an argument or anything, Buff, but I always thought of the "Running Rabbit" as the RAIL lights, which are defined as Sequenced Flashing White Lights, these are the lights that are integrated into most of the approach light systems shown in the approach lighting layouts in my approach plate book, and those are the ones I assume I've seen at all the airports I go into.
ODALS are defined in my book as Omnidirectional , not Sequenced.
 Big thumbs up
Tue Jan 30, 2001 12:21 pm
Omni-directional Approach Lighting System is a series of omni-directional strobes with omni "rabbit" lights and omni REIL lights. The "rabbits" are defined at RAIL as seen in many common ALSF-1 and ALSF-2 approach lighting systems. The omni system follows an actual vertical arc down to the runway. You can see them for about 8 miles and I believe some airports down in Louisiana, Mississippi, or Arkansas may still have them. I have seen them in person before. Note below:
Ralgha
Tue Jan 30, 2001 4:41 pm
The charts show RAIL lights and ODALS lights as different. They look different I assume too. "Omni" means all directions, RAIL can't be seen very well from the side. REIL are masked so you can't see them from the side and aimed at an angle of approx. 10 degrees.  Big thumbs up
Buff
Wed Jan 31, 2001 12:25 am
Jepp: ODALS - including sequenced flashing lights (rabbits);
Air Canada: "P" type/ODALS with sequenced flashing lights.
Omni-directional means that they can be seen from all directions as opposed to when you're lined up on them, much as runway edge lights are partially focussed.
Best Regards,
Buff
Sun Feb 04, 2001 2:51 pm
I went down to the airport(CYKA) and checked. They indeed are the running rabbit kind. They look pretty cool close up, but the bright strobes strain your eyes. Are they a new development or old technology?
p.s. the ODALS lights replaced the old apprach lights about a month ago..............
Buff
Sun Feb 04, 2001 3:25 pm
"Running Rabbits" are an old (older than me) kind of approach lighting aid designed to attract one's eye from an initial approach point to a runway threshold. The formal term "ODALS" has incorporated this "older" technology.
Best Regards,
Buff
Sun Feb 04, 2001 4:00 pm
How would you rate them in terms of visibility and performance?.....are they better than a row of non-flashing lights?
Buff
Mon Feb 05, 2001 5:38 am
They are most useful to me, in locating the final approach segment from a good distance away. On final approach though, for the most part, I find them quite annoying. In the past, I'd ask for the sfl's to be turned off, but at the airport I asked, they were unable without turning out the rest of them (edge, thld, REILS) too!
Best Regards,
Buff
Users browsing this forum: lightsaber and 1 guest
