modesto2
LAX "Lima 16"
Tue Feb 20, 2001 7:57 am
I heard clearance giving some San Diego bound flights this "Lima 16 routing". Could someone please enlighten me...? Thanks.
RE: LAX "Lima 16"
Tue Feb 20, 2001 8:36 am
I think is is a SID, I am trying to remember the one I got when I had to go out of there IFR. I think it was Seal 3, but I am not sure! All my jeps are at home (in California) so I am unable to pull it out and have a look, however it sounds right!
Iain
RE: LAX
Sat Feb 24, 2001 8:42 am
Fortunately I brought my Jepps home today so I can give you an answer. What you heard was a Tower Enroute Control clearance. Here's what Jepp has to say:
Within the national airspace system it is possible for a pilot to fly IFR from one point to another without leaving approach control airspace. This is referred to as "Tower Enroute" which allows flight beneath the enroute structure.
My Jepps have 4 pages worth of routes from any of the airporst within the boundries of Socal Approach. Basically there is so much "local" approach control that a pilot on this routing will never have to contact Center to get to where he's going.
So the "Lima 16" routing is the LAXL16 route between LAX and any of the San Diego airports. The clearance follows a series of VOR radials leading to the Mission Bay VOR, then most likely a clearance to the specified airport is given.
Hope this helps!
SWP
Users browsing this forum: mattyfitzg and 1 guest
