MCPilot
Cessna 206 Engines
Sat Mar 03, 2001 3:43 am
Has anyone heard about the new lycoming engine problems of the new production of cessna 206
desertjets
RE: Cessna 206 Engines
Sat Mar 03, 2001 4:12 am
All I know is that all new Cessna's, indirectly as a result of Cessna being owned by Textron are all powered by Textron Lycoming Engines. The C-206 uses the IO-540 or the TIO-540 which I believe is flat rated at 300hp, whereas the old Continental IO-520 was rated at 285 and the TSIO-520 was rated at 285 continuous, 310 for takeoff.
tom2katie
Sat Mar 03, 2001 12:21 pm
I was curious to see how they would fit a big lyc into the cowling of the 206. Not much room for lycomings goofy induction system with the tunnel structure cessna uses to support the nose gear. A lycoming installation would require either a complete redesign of the engine itself, or a redesign of the front end of the 206 to allow a tubular mount system like that which is normally required by lycoming engines? hmmmm.. Anyone have any pictures?
chopper
Sat Mar 03, 2001 1:23 pm
Those are nice planes I can tell you that. My dad use to own a 68.
chopper
Sat Mar 03, 2001 1:27 pm
Wow! I just went to flightdata.com and it is still up and running. N29096. He lost it in the 80s rececion
