modesto2
Pilot's Discretion
Wed Mar 07, 2001 4:35 am
What's the purpose of pilot's discretion to a flight level? I understand the definition of PD but WHY is it used? When is it used? How often is it used? Any info regarding PD is appreciated. Thanks!
spoiler
RE: Pilot's Discretion
Wed Mar 07, 2001 5:13 am
Well, I've never flown in the flight levels (as a pilot anyway), But I'd imagine that PD might have something to do with severe weather avoidence. Some of those thunderstorm tops can go up to FL400. But like I said, I'm not really sure.
XFSUgimpLB41X
Wed Mar 07, 2001 5:25 am
It is basically a term used when you have plenty of room to work with.... i get PD descents all the time down at the lower altitudes i use (12,000 and below usually)... I guess you could say it is the opposite of expediting. And yes, it is also used for weather/buildup avoidance...although in that case i am almost always told: "when able, climb/decend and maintain (insert altitude here)"
Chicks dig winglets.
AAR90
Wed Mar 07, 2001 11:11 am
As stated earlier, if plenty of airspace to work with the controller can issue a P.D. clearance when workload and radio traffic volumn permit.
>When is it used?
Most often sometime prior to normal top of descent point for a lower altitude crossing restriction.
IMHO, I'd guess as often as traffic and workload permit. Removes burden from ATC and places it upon pilot --who probably wants it so he can perform descent the way he wants rather than the way ATC wants.  Wink/being sarcastic
Unless traffic volumn is real high, I see this just about every flight up/down west coast. Usually ATC issues PD clearance shortly after we "request lower."  Big thumbs up
Wed Mar 07, 2001 2:09 pm
In my experience listening to Seattle Center, the controllers tell the pilots to 'descend pilots discretion and maintain FL240' so that the pilot can choose his descent rate and time to start down, keeping in mind the arrival restrictions. Often a pilot checks in on the next freq "Alaska XXX with you, pilots discretion FL240" and the controller will respond with "Alaska XXX, cross JAKSN at 16000, descend and maintain 12000, Seattle altimeter...blah blah blah".
So basically, from what I have learned, its just so that the pilot has a bit of freedom with his descent and the controller doesn't have to do the math in his/her head on when the start the aircraft down.
Fri Mar 09, 2001 1:59 am
N766AS, in your example above, it's the high altitude controller giving PD to FL240. He does this getting ready for the handoff to the next contrller working FL240 and below. I'm not sure if he flashes the aircraft to the next controller right away or when they start down. Like AAR90, I get PD clearances all the time flying in the Pac. NW. It's a workload issue on the controller's part. If there's room, it's easier to let the pilot plan his or her own descent.
CX Flyboy
Fri Mar 09, 2001 2:13 pm
In modern airliners, the FMS calculates the top of descent point and marks it on the ND (Navigation Display). When this point is reached, as long as a lower altitude is dialied into the autopilot window, the aircraft will automatically retard the thrust levers and begin descent. If descent is initiated before this, then we will be below optimum descent profile.
A descent at pilots discretion before this point means that we can descend when we prefer to, as opposed to immediately.
Fri Mar 09, 2001 2:31 pm
Yeah, I think I was trying to get at that (but it was probably lost in all the other crap...hehe). I know that the controllers (at least the ones I listen to regularly) have a VERY high workload just about all of the time.
I have yet to drive down to Seattle Center (its only a few miles down the road) to watch them in action in person- I think that would be a great experience.
