A/c train
Spinners
Tue Mar 13, 2001 3:37 am
On some engines I have seen The spinner has a little bit of rubber on the very tip of the spinner to stop Ice build up by vibrating , how do other engines do this? engine bleed air?
VC-10
RE: Spinners
Tue Mar 13, 2001 5:04 am
RR Fan Engines have the rubber tip, GE & PW don't bother with anti-iceing the spinner.
RR Spey's & Conways used bleed air to antice the inlet dome.
PW didn't antice the JT3D dome
RE: Spinners
Tue Mar 13, 2001 5:16 am
VC-10,
PW did design the 305 with anti-ice in mind, the spinner is provided engine bleed air full time
VC-10
RE: Spinners
Tue Mar 13, 2001 5:29 am
I don't know the 305
RE: Spinners
Tue Mar 13, 2001 4:26 pm
VC-10,
the PW 305 is used on the Lear 60 and the Hawker1000.
it is a 4600 lbs of thrust on the 60, a small engine relatively speaking, but a real kick in the pants if you ever get to ride in a 60.
F-WWAI
RE: Spinners
Thu Mar 15, 2001 12:55 am
Yes, the rubber tip is there for anti-ice primarily and is very efficient. It is a RR patent, I believe.
Some poeple suggested if might have been introduced at RR because an executive poked the original spinner tip in his ear or eye while walking around an engine on the floor... talks?
 Smile/happy/getting dizzy
FW
Users browsing this forum: sailsman1 and 1 guest
