Mr Spaceman
DC-9 Nosegear Question
Sat Mar 17, 2001 6:25 am
Hi There. My Question is. Why do some versions of the DC-9 have what appears to be some sort of horizontal apparatus attached to the back of the nosewheels? After decades of watching DC-9's taxi pass me at Toronto's Pearson International, I still have no clue. What is it!? Can you help me? There are some good photo's of this mysterious object in Photo ID#148184, #147736, #147092, #132829 Thank You....Chris
RE: DC-9 Nosegear Question
Sat Mar 17, 2001 6:54 am
I am pretty sure it is a gravel kit, however I might be wrong!
Iain
OPNLguy
Sat Mar 17, 2001 7:13 am
If you go over to the NTSB website (http://www.ntsb.gov) and look for this accident, you can access a .PDF file of the accident report itself:
Title: Ground Spoiler Activation in Flight/Hard Landing, Valujet Airlines Flight 558 Douglas DC-9-32, N922VV Nashville, Tennessee, January 7, 1996 NTSB Report Number: AAR-96-07, adopted on 11/11/1996 [Abstract | PDF document]
NTIS Report Number: PB96-910407
If you scroll down to page 153, they have a diagram of the nose gear, and this is what the manual says about the item you're curious about:
Nose gear spray deflector..
Deflector minimizes water and/or slush ingestion during takeoff and landing. (If installed).
I'm not current on DC-9s or newer MD80/90 variants, and I don't know if these newer ones are so-equipped. Presumably, the longer fuselage length(s) of the newer ones (plus use of chined nosetires) made these spray deflectors obsolete.
AAR90, ya out there to confirm/deny?  Big grin
The appearance of this item on the DC9 is similar to that part of the 737 gravel kit, but the DC9 application appears to be due to its engines so close to the aircraft centerline, and thus the more common threat of water/slush ingestion...
AAR90
Sat Mar 17, 2001 7:46 am
Don't know what regulation or certification requirement(s) exist, but every AA MD80 & MD90 has spray deflectors installed on both main gear and nose gear struts. I'd have to check an MEL to see if operation is permitted without spray deflector(s) installed and if so, with what limitation(s). Spray deflector installation was strongly emphasized during my initial MD80 training in 1988.
JT8DJET
Sat Mar 17, 2001 8:07 am
I think the shorter versions of the DC9 have chined tires and the longer versions & 80/90's use the deflector.
AAR90, Can you confirm that your A/C don't have chined tires?
For those that don't know what a chine tire is, it is a rubber edge that sticks out the sidewall of the tire. This would act as a deflector. All 727's have a chined tire on the nose gear.
OPNLguy
AAR90
Sat Mar 17, 2001 8:37 am
Thanks for the info on the newer versions. Wonder why MD had "(if installed)" in the older manuals...
AAR90
Sat Mar 17, 2001 11:31 am
Back when I flew the airplane, all MD80s had chined nose wheel tires. Don't recall if that was mentioned when I took the MD80 course a year ago because I was only in the course so I could get to the MD90 and all instructors knew that and tailored their instruction toward MD90 systems rather than MD80 systems (as much as they could). MD90 nose wheel tires do _not_ have chines.
Mr Spaceman
Sun Mar 18, 2001 3:31 am
Hi guys. This is Chris. I can't thank you enough for your feedback on my question. I am "Very" impressed by the amount of knowledge that you gave me so fast. I hope it makes you feel good inside to be able to help a fellow aviation nut! Believe me it is really, really appriciated. Once again...Thank You!
A/c train
Sun Mar 18, 2001 4:30 am
Hydraulic steering cylinders?
Panman
Sun Mar 18, 2001 4:37 am
No A/c train. Steering cylinders are higher up on the oleo and not aft of the nosewheels
PHLyBoy
Sun Mar 18, 2001 11:02 am
Delta's MD-88's have the splashguards on the front gear, no "chined tires like our 727's however. They told us in training that the MD's splashguard costs upwards of $10,000, and make sure we don't chock it!!!!!
wilcharl
DC-9 Nose Gear? For Deep DC-9 Freaks
Sun Mar 18, 2001 12:45 pm
Another question for yout hat I havent gotten a straight answer for. ON a few -9s (chinned tires of course) i have noticed a 3/4 inch wide rubber staraped that is attached within 3 inches of the top of the tire to the aft of the strut. It has a nut there, and its it is a strip of rubber hanging verticaly down approximently 8-10 inches 3" inch wide. Almost looks like a piece of electrical tape... Pilot had no idea what it was just knew it was suppose to be there on some a/c. Same thing for MX... Im sure its insignifigent since even MX wasnt sure as to why the guys in long beach stuck it there.. Ive seen it only on a few -9s
TomH
Mon Mar 19, 2001 8:55 pm
I always thought the aft-mounted engines FOD suseptability (especially at high angles of attack) was the reason for those kits on the DC-9 series-but I'm probably telling you something you know quite well.
Say, what's a chined tire?
TomH
-9's/-80's
Tue Mar 20, 2001 1:56 pm
the DC-9's have chined tires...the MD-80's have splash guards. I work for Midwest Express...that's all we fly and I'm pretty sure it's that way for all -9's and -80's.
milo
Wed Mar 21, 2001 1:27 am
Excelsior767
It is not that way for all -9. I work for SAS and all our dc-9, md-80 and md90 have spray deflectors on all 3 gears.
Mr Spaceman
RE: DC-9 Nosegear "Photos"
Fri Mar 23, 2001 10:13 am
I decided to add these shots for those who might still read this question.
----Now that I know how to do it!
Chris
Click for large version
Photo © Pierre Lacombe
Photo © Jason Whitebird
Photo © Bruce Highland
Photo © Marlo Plate
srbmod
Sat Mar 24, 2001 4:02 pm
The 717 also has the spray deflector. I was working as a ramper at AirTran when they the 717, and remember them in the 717 training class (lasted all of 15 minutes during my shift one day) telling us to be careful when attaching/removing the towbar from the nosegear, so that the deflector would not get damaged. Here are some photos that show the deflector:
srbmod
Sat Mar 24, 2001 4:05 pm
Sorry about the photos. Here they are:
Photo © Scott Leazenby
Photo © Rob Simmons
Photo © Stephen Tornblom
Photo © Rob Simmons
Photo © Michael Carter
L-188
Sun Mar 25, 2001 12:01 am
Tomh. it isn't the distance aft of the nosegear that gets you it is the angle that the tire throws the spray up at that gets it. I have seen footage of the 727 prototype going through a spray track first without chined tires and then with the chined tires. The chines sent the spray much further outboard.
All of the MD-80's at Alaska when I worked there had the spray guards. It is cheaper to have them then chined tires.
Chined tires from my understanding are much more expensive then standard tires.
RE: -9's/-80's
Mon Mar 26, 2001 11:07 pm
I stand corrected. At Midwest Express anyway, all the -9's have chined tires, the -80's have spray guards.
Mr Spaceman
RE: Srbmod's Photos
Tue Mar 27, 2001 4:58 am
Hi there. I just wanted to say "Thanks!" for the great photos. That's the closest view I've ever had of these objects that "were" a Mystery to me.
Chris
Soku39
Tue Mar 27, 2001 12:56 pm
anyone have any pics of chinned tires.
The Ohio Player
Users browsing this forum: citrusrsw, DC8FanJet, futuresdpdcop, lotpilot16 and 2 guests
