Western727
767-400: Those Funny Things On The Wingtip
Wed Mar 21, 2001 3:01 am
To anyone who knows:
What are the purpose of those strakes (I think they are called strakes) on the wingtip of the 767ERs? This topic seems like the type of thing to post in the Tech/Ops forum.
Jack @ AUS
310_engineer
RE: 767-400: Those Funny Things On The Wingtip
Wed Mar 21, 2001 3:12 am
Is it possible that you mean the static dischargers?
Spacepope
Wed Mar 21, 2001 3:27 am
They are indeed strakes. From what I understand, they serve the same purpose as winglets, they're just oriented differently. They smooth out the airflow over the wingtip so that the vortexes do not sap so much energy, and cause too much drag. Perhaps someone can get more technical than this, I'm just a geologist, and it's been about 3 years since my last class in fluid flow. reynolds number? Froude number? I couldn't tell you.
T.J.
Spacepope
Wed Mar 21, 2001 3:32 am
My bad, they're called "raked wingtips" by Boeing.
T.J.
Western727
Wed Mar 21, 2001 3:33 am
OPNLguy, that photo was from an A32O or an A319. And I'm not talking about static wicks. I'm talking about the strakes (the smashed-winglet lookin' things). Spacepope, thanks for your info. I'd love to hear more.
Jack @ AUS
Western727
RE: How About These?
Wed Mar 21, 2001 3:46 am
No, they are not vortex generators. Think "wingtip."
In the place of winglets, there are strakes. They look like extensions of the wing.
Jack @ AUS
310_engineer
Wed Mar 21, 2001 3:48 am
I think this is what he means:
Click for large version
Photo © Ryan Gaddis
Western727
310_engineer
Wed Mar 21, 2001 3:50 am
That's exactly what I'm talking about.
Jack @ AUS
Western727
My Bad...
Wed Mar 21, 2001 3:51 am
My bad for not putting up the picture in the original post...
Jack @ AUS
310_engineer
Wed Mar 21, 2001 3:54 am
Great
Now I know where you are talking about, I will try to find some info.
JETPILOT
Wed Mar 21, 2001 3:55 am
They're not "strakes". What the hell is a strake. They're called raked wing tips.
310_engineer
Wed Mar 21, 2001 4:06 am
Yep
raked wingtips
Spacepope
Strakes And Raked Wingtips
Wed Mar 21, 2001 4:27 am
A strake is what you call the part of an aircraft that blends the wing into the body. Look an an F-16, those are called Leading Edge Strakes. The give significant drag reduction and contribute to lift.
The raked wingtips help smooth out the air in the area where the low pressure air above the wing may mix with the high(er) pressure air from below the wing. think of it as keeping it from spilling out from uder the wing. Many techniques have been tried to eliminate this problem. Earlier attempts include wing fences and winglets. This Boeing mod on the 764 is just one more technique that appears to work.
Now for all you engineers- does the raked wingtip pose any significant advantage over a vertical winglet?
T.J.
Mr Spaceman
RE: Jetpilot
Wed Mar 21, 2001 4:33 am
You can find a "Strake" on each side of the belly of a U.S. Marines "Harrier" fighter jet. They look like long "Wing Fences" only upside-down on the belly. I believe they serve the same purpose, they help control airflow direction. ---Maybe these "Raked" wingtips simply contain the wire harnesses for the tip lighting on wings with "extended" range fuel tanks. [I couldn't tell ya!]
Western727
What's With The 'tude, Jetpilot?
Wed Mar 21, 2001 5:26 am
It was a simple question. I was just guessing what the name was. In fact, part of my question was what the proper term for them was. What's with the attitude?
Jack @ AUS
777X
Wed Mar 21, 2001 5:51 am
AFAIK they are similar in purpose to winglets but were used on the 767-400 (and the upcoming 777-200LR/300ER) as they require less wing strengthening than 'typical' winglet designs.
UAL747
Wed Mar 21, 2001 4:00 pm
I'm not a physics major; however, the raked wingtips do provide an advantage over the vertical ones. Basically, the raked wingtips are an extension of the wing itself. While discouraging overspill of high pressure air onto the top of the wing where low pressure air is present, they also, by being horizontal, give extra lift, kinda like an extension of the wing.
UAL747
Western727
Wed Mar 21, 2001 11:19 pm
Ok, makes sense.
Jack @ AUS
cedarjet
Is This The 'Tude To Which You Refer, Western727?
Thu Mar 22, 2001 1:48 am
I'm with JET on this one, what the hell IS a strake?! It's a very irritating word as well. As is, "'Tude".
Western727
Cedarjet, Jetpilot.
Thu Mar 22, 2001 2:06 am
Yes, that's exactly the attitude I'm talking about. My question for you is: How does one ascend to your station in the aviation community, Cedarjet and Jetpilot, without hearing the word 'strake?' I'm just a private pilot, and I've seen the word used commonly in aviation books, magazines, websites, etc. One article stands out particularly. The topic was the Beech 1900D. One can't really describe that airplane *without* using the word 'strake.' Now, my concern is not that you don't know what a strake is. My concern is that you voiced your confusion in such an impolite manner (and that goes for both of you). It was, after all, a simple question. And I don't recall doing anything to offend either of you on any prior occasion. So I ask again: Why lash out at me for trying to educate myself? Why lash out at me at all? If you'd like to know what a strake is, try, just for a moment, to step out of your arrogance, and do some research.
Jack @ AUS
A/c train
RE: Cedarjet, Jetpilot.
Thu Mar 22, 2001 2:27 am
Well said Western 727, when im being taught by pro AMT's there generally ' TOP BLOKES' , who have enough time for you and DONT barf at you when you are confused, or pronounce something wrong , I have learnt so much by being with these people and would always listen to what they say , CUT THE KNOW IT ALLISM no one knows everything !and as 310 said to me once were all here to learn.
:D
FDXmech
Thu Mar 22, 2001 2:47 am
Actually "strakes" are a valid nomenclature. Example: observe the forwrd fuselage below the rear cockpit window and above the nose gear on the MD80. Those short winglike (reminds me of a popsickle stick) appendages are called "strakes".
EssentialPowr
Thu Mar 22, 2001 3:37 pm
"They're not strakes. What the hell is a strake..."
GREat Attitude. The term wasn't covered in the degree program at Bastardization of Science U...Probably shouldn't bring up the phrase "REynold's #" either...How bout "Payfertraining?" Now!! Here comes the dissertation...
Spacepope gives a good description. In particular, strakes maximize high alpha capability on fighter aircraft, and give the f16/18 (and of course Mig29/Su27 etc) the hooded cobra look.
AW&ST gave a good account of why the raked tips were selected for the 76-400 vs winglets, which essentially boiled down to the fact that the winglets required beefier structure to support, but gave around 3% decrease in drag at cruise altitudes only (a la typ winglet). The raked tips give about a 1% decrease in drag in all flight regimes, did not require any strengening of the structure, and are CDL able. If one gets dinged, take off the other, adjust the perf numbers, and go fly.
Cheers-
srbmod
Tue Mar 27, 2001 3:14 pm
Boeing's calling them raked winglets. They had experimented in a wind tunnel with various winglet designs, (blended, vertical, raked) and the raked design won over because of one very important reason. All three types of winglets are good, but the raked winglet allows the 767-400 to use a gate without affecting the operation of neighboring gates.
flyf15
Wed Mar 28, 2001 6:38 am
A "Strake" is basically any fin type chunk of metal that isn't part of the basic wing, horizontal, or vertical tail surfaces that contributes to the stability or aerodynamics of the aircraft. Examples, as stated before, are those on the B1900D, MD-80 nose, and the devices that lead from the front edge of an F-16's wing towards the cockpit.
I've never heard of a winglet refered to a strake, although from the definitions I've heard, I assume it could fall into the "strake" catagory vaguely.
Photo © Craig Murray
Users browsing this forum: thepinkmachine and 11 guests
