Mr Spaceman
767 Vs 757 Landing Gear?
Thu Mar 22, 2001 4:51 am
Hi guys. My question is, Why does the "Main" Landing Gear on a Boeing 767 have the front wheels hanging "lower" than the rear wheels on the boggie assembly? This looks strange to me. However it must serve some purpose. The Boeing 757's "Main" Gear wheels hang like most of the other Airliner jets, with the trailing wheels hanging the lowest. [Apparently, pilots can transition between a 767 and 757 quite easily because their systems are so alike], but why the difference in the Gear? I've been wondering about this for years!
Chris
Click for large version
Photo © PixAir
Photo © Mark Abbott
Check out the Gear "Stance" on this beauty!
Photo © Felix Sieder
Wardair Canada
RE: 767 Vs 757 Landing Gear?
Thu Mar 22, 2001 7:18 am
Chris,
I am not too sure 100% on the facts that I'm about to say about the 767 gear stance...but I heard it was due to the fact that Boeing engineers realized too late that the gear bay would not fit the 767's bogies so they had to articulate it, or the fact that to eke additional range out of the 767 without doing major redesign by adding more fuel tanks and thus the bay size was reduced and they decided to articulate the bogies. I am not 100% certain, but somebody else is....I'll leave that answer to them.
But what I can tell you is there is an answer for the A330/A340's unique articulated bogies. It is not because the bay is too small or the gears are too heavy that they hang rear wheels down first.
When Airbus first designed the A330/A340, the main gear assembly was designed to give optimal ground clearance and control while the main gear is still on the ground. It provides better pitch control and additional ground clearance. In other words, the gear remains on the ground a bit longer. This is helpful especially in landings.
Jason
fanoftristars
Thu Mar 22, 2001 7:49 am
I remember this topic being discussed before, and the general consensus was clearence in the wheel bay.
What is not clear to me is how this affects the aircraft landing. Do all four wheels touch together, or do the front wheels hit first? I also heard that smooth landings are more difficut on the 76s because of this, but I havn't heard a reputable source back that up.
"FLY DELTA JETS"
Mr Spaceman
RE: Wardair Canada
Thu Mar 22, 2001 8:01 am
Thanks for your response, Jason. Very interesting about those engineers and what they're up to some times. I must say, I love the landing gear on the A330. They make the aircraft look more "Alive!"
Chris
Wardair Canada
RE: Wardair Canada
Thu Mar 22, 2001 8:45 am
Chris,
I agree with you, the A330 looks lively with that kind of gear stance....it also gives it a "tippy-toe" kind of attitude when landing. The plane would tip toe for a few seconds then settle on all 4s.
The A340-500 & -600 will have a 4 wheel center gear bogey..yes 4 wheels instead of the usual 2 found on the A340-300. It will articulate like the main gear bogies so it should be an interesting sight to see.
Later,
Jason
flight152
Thu Mar 22, 2001 9:42 am
Well than on the Boeing 747 why are the outter bogies tilted and the two innner ones are not, is it space?
Photo © Søren Geertsen
cdfmxtech
The Truth About The B757 Gear
Thu Mar 22, 2001 1:14 pm
For the record...the B757 gear WILL ENTER THE WHEEL WELL not tilted. It has been proven..recently at my airline. The B757 gear has something call a truck tilt positioner that with weight OFF wheels will position the gear with the fwd most wheels elevated. Well, there was a malfucntion that I won't go into too much detail about, (becasue this not the tech forum), but the truck couldn't tilt. Now the flightcrew could not normally raise the (that is without using the gear override button) because the B757 gets its Air/grnd sensing from those tilt sensors. But it will go into the wheelwell physically.
B767 is similar
cdfmxtech
RE: The Truth About The B757 Gear
Thu Mar 22, 2001 1:18 pm
OK....I just realized I WAS IN THE TECH FORUM. There is a hydraulic fuse right off the truck positioner shuttle valve. It went bad, and there was no hyd pressure downstream (worked as advertised) to position the truck positioner.
Sun Mar 26, 2006 7:08 pm
Quoting Cdfmxtech (Reply 6):
This is news.
Quoting Cdfmxtech (Reply 7):
Only on the LH shuttle valve side for both MLGs.
regds
MEL
vikkyvik
Sun Mar 26, 2006 9:31 pm
Every thread that I've seen on this subject (and there have been a few!) has come to the consensus that various bogey positions are due to the way the gear fits into the wheel well. I'm not an expert on this, but this is what I've read on this forum. Hey, here's a thread on this very subject:
http://www.airliners.net/discussions/tech_ops/read.main/128910
HAWK21M, glad to see you post again. Where'd you go?
~Vik
EDIT: D'oh, I just noticed that this thread was 5 years old! I saw that it was posted in March, and just assumed it was March 2006! Oh well, at least it wasn't me who brought it back  Smile
[Edited 2006-03-26 13:42:16]
Mr Spaceman
Sun Mar 26, 2006 11:51 pm
Hi guys.
Quoting Vikkyvik (Reply 9):
~Vik
>> Hi Vikkyvik,
I was really surprised to see a topic near the top of the page about the 767 versus the 757 .... with my username as the thread starter!  Confused  eyebrow  I thought there was a malfunction with a.net because I knew I didn't post anything about landing gear for a Long Time.
HaHaHa! It's neat to read a post you did over 5 years ago!  Silly
>> Hello HAWK21M, I'm also glad to see you post again. You must have been doing a good search to dig up this thread!
As many others in this forum, I too have been wondering where you went?
I hope you were not in prison!  biggrin   Wink
Chris  Smile
fr8mech
Mon Mar 27, 2006 1:16 am
OK for the record, the gear on a B757/B767 is positioned (tilted) so that it will fit in the wheel well. Here is a quote from the B767 AMM:
"Truck Positioner (Fig. 9) (1) The truck positioner is a hydraulic actuator which tilts the truck to fit into the wheel well during gear retraction."
Cdfmxtech, who do you work for? I was just involved with a B757 that had the fuse on the shuttle valve set. The gear will go in the wheel well, after bouncing off the doors, as evidenced by the skid marks on the door.
Without pressure on the tilt positioners (both aircraft have them), the bogie is free to 'flop around' after takeoff. If the tilt sensors (sys 2) show 'not tilted' the gear safety override will not pull. The flight crew can override the switch and retract the gear, an untilted gear will be tilted as it rides along the door.
A point of note, when the gear is tilted by the door, the sensors will will show tilted and any messages that may have appeared will go away.
Quoting Flight152 (Reply 5):
The body gear are tilted on a B747, just not as much as the wing gear. I would be very reluctant to press the override on a Jumbo if the wing gear show untilted after take-off (the classics can tell you, don't know about the -400). The body gear should be able to fit in its hole, but the wing gear, due to its extreme, required tilt, will probaby run into structure and/or the body gear if an attempt is made to retract with an untilted wing gear.
Mon Mar 27, 2006 2:05 pm
Quoting Mr Spaceman (Reply 10):
The Thread popped up on a search.Found it interesting.
I was attending Boeing Theory Training on the B752 by Alteon. It was a 45 day course with lots of studies.Another 3 day Engine differences [-535C & -535E4], 3 day Pax to Freighter conversion course & Practicals [2 weeks] are due in April end.
regds
MEL
DH106
Tue Mar 28, 2006 1:09 am
But if a tilt actuator IS required to tilt the bogie during retraction to fit the gear well, that STILL doesn't answer the question as to why the bogie tilt is required when extended. Why doesn't the tilt actuator just position the bogie flat when extended, and to whatever required by the well geometry during retraction? To my mind, the issue of gear well shape & geometry is a red herring, the differential spin-up on touch down arguement seems more plausible.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
Tue Mar 28, 2006 1:15 am
On the B752.Apart from Fitting into the MWW.The Tilt Actuator provides the Tilt used for Air-Grd sense.
regds
MEL
fr8mech
Tue Mar 28, 2006 1:31 am
Quoting DH106 (Reply 13):
Why make the system more complicated by having multiple settings? Remember, these aircraft are 70/80's technology. I realize the newer aircraft have multiple settings dependant on phase of flight, but not these 2.
These 2 aircraft (B757/67) have fixed tilt. When the aircraft is in the air the tilt does not change. The bogie tilts and the gear fits in the well. To answer the question of why one is tilted one way vs. the other, take a look at the B767 main gear. The whole amin gear assembly is canted aft (pivot point forward), this may explain the reason for the forward tilt. Next time I'm atound a gear retraction, I'll look at it closer, but being at a line station, a retraction is a rare and bad thing thing.
DH106
Tue Mar 28, 2006 2:01 am
Quoting Fr8Mech (Reply 15):
But the arguement that the tilt is needed because of the geometry of the retraction angles/gear well geometry is only valid if there isn't a tilt actuator moving the bogie during retraction. If you do then add a tilt actuator (as in our aircraft), then only 2 tilt positions are required - those for gear extended & gear retracted. Since we seem to be agreed that these aircraft do have tilt actuators, the question still remains: Why were those gear extended tilt angles chosen.
Hey cool Fr8Mech  Smile Any chance you could get a video next time ! Would love to see that up close.
fr8mech
Tue Mar 28, 2006 10:25 am
Quoting DH106 (Reply 16):
There is only one tilted position. Anytime the aircraft is in the air with hydraulics on the bogie is tilted. Any position other than tilted is untilted. This is not a commanded position. It is a position that is induced, usually, by the weight of the aircraft on the wheels. When the gear is extended or retracted the tilt remains the same.
bohica
Tue Mar 28, 2006 10:33 am
I didn't realize you could respond to a thread which was archived 5 years ago. Look at the dates on the early posts.
DH106
Tue Mar 28, 2006 6:31 pm
Quoting Fr8mech (Reply 17):
Okay - perhaps I've misunderstood the function of the tilt actuator. Does it merely return the bogie to a preset angle on leaving the ground - there's no 'dynamic' repositioning behavior on retraction on the 757/767 ?
The 777 certainly does this - normally the 6 wheel bogie is positioned 'rear wheels down', but as the main gear doors open, the bogie is tilted to approximately flat before the gear legs pivot in.
Take a look at this and note the bogies are approximately flat and not in their normal position:-
http://www.airliners.net/open.file/1023326/L/
Tue Mar 28, 2006 11:19 pm
Quoting Bohica (Reply 18):
I don't think it was ever archived.
fr8mech
Tue Mar 28, 2006 11:28 pm
Correct, it's my understanding that the B777 does have multiple positions. The B767/57 does not.
Wed Mar 29, 2006 12:27 am
That would be Interesting.Too bad out here its not possible to Photograph inside Airports.
Quoting DH106 (Reply 19):
9.6 degrees on B752.
regds
MEL
Mender
Thu Apr 20, 2006 4:44 am
The reason the main gear tilts forward IS to fit in the wheel well. Conventional thought is that the main leg pivots at 90 degrees to the airframe thus it is hard to understand why the gear is tilted at all.
The REAL reason the gear is tilted is that the main leg DOESN’T pivot at 90 degrees to the airframe. It actually pivots at an angle such that it moves forward in an arc. Thus if the truck beam was parallel to the main leg the rear wheels would be closer to the keel beam of the airframe. To reduce the track of the gear they tilt the truck beam so that it stays parallel to the keel when it is retracted.
When the gear is retracted in the bay and the gear lever selected to off the gear rests on a linkage attached to the hinge line of the door on the keel beam. Part of this linkage is attached to the door/keel beam of the airframe and part of it is attached to the truck, on the pivot point of the truck beam to main leg. If you were to view the aircraft on the ground with the gear doors open looking at the uplock fitting on the truck pivot point you can see that it is aft of the uplock link on the door/keel beam. The uplock link on the door is actually slightly forward of the front axle with the gear down, that’s how much the gear arcs during retraction.
When you look at the top of the leg it’s easy to see that it is “bent” over at the top but it is also “twisted” in relation to the truck beam. Whilst this is not as easy to see, the pivot point (or trunnion) is further inboard at the rear trunnion bearing than it is at the forward trunnion. This makes the gear arc forward during retraction.
I speculate that the design engineers at Boeing had a structure to fit the gear into and a position to place the gear in so that the centre of gravity didn’t make the aircraft fall over on the ground. These two didn’t match unless the gear was to arc forward, thus they needed to tilt the gear against popular convention and that was that!
kaddyuk
Thu Apr 20, 2006 6:05 am
I'm Not sure in regards to the B75/76 actuator however the A340 gear is set up so that if there is no Weight On Wheels the gear will naturally tilt of its own accord, however the reason for the tilt actuator is to force the bogie beam into the tilt position if for any case, it doesnt tilt naturally. This is because of how the gear fits into the well... There is also a shortening link which actually shortens the landing gear and then actually extends it so that the gear will fit in the bay correctly AND all the doors close correctly.
The reason the A346 CLG is rotated 180 degrees to the rest is because that landing gear flips upside down and the wheels sit in the roof with the Leg Underneath, its such a complex method of retracting the gear.
It seems that manufacturers design the aircraft, then send the specs to whoever makes the landing gear and says "Make It Fit".
DH106
Thu Apr 20, 2006 6:21 am
Quoting Mender (Reply 23):
It's all to do with 'relaxed stability' - moving the CG rearward to unload the tailplane with the aim of reducing drag, whilst letting computers worry about the aircraft's stability. Unfortunately - this means the gears have to be located further to the rear, and if the wing is swept as well this leaves the gear very close to the TE. So the solution is the complex swinging/pivoting gear very well described by Mender
David L
Thu Apr 20, 2006 6:28 am
Quoting Kaddyuk (Reply 24):
Makes more sense than having the gear manufacturer telling the aircraft manufacturer to "rotate your aircraft around this".  Smile
LFutia
Sun Apr 23, 2006 1:52 pm
Quoting HAWK21M (Reply 22):
Namaskaar Mel.
I believe the restrictions were uplifted from airports that dont have military presence in them.
Leo
gt1
Thu Apr 27, 2006 8:47 am
It's taken me 8 years of very close association with this airplane to figure out what Mender told us in a few paragraphs! Great post!
If I may, I'd like to say it in a slightly different way to help some of the folks who are trying to work it out: the axis of rotation of the main landing gear in the wing is NOT parallel to the direction of travel of the tires.
A3204eva
Thu Apr 27, 2006 8:53 am
Don't have time to read every reply atm so if what I am about to say has been previously said above, I appologies  Smile
Boeing didn't intend for the main gear to tilt at all, but as it was assembled they found a weight problem which caused the tilt, but it didn't make a difference and so they didn't correct it.
 Smile
"They have lady pilots......... they're not that good, but they have 'em"
fr8mech
Thu Apr 27, 2006 10:39 am
Quoting A3204eva (Reply 29):
So they installed the tilt actuator for giggles?
Sat Apr 29, 2006 2:09 pm
Quoting Lfutia (Reply 27):
True.But not on the Tarmac.Only as a Scheduled Pax from Inside an aircraft at Non Military Airports & Terminal Buildings.
AIC 8of2005
regds
MEL
[Edited 2006-04-29 07:15:33]
