Normal Speed?
Wed Apr 25, 2001 8:53 am
This is a very simple question for most of you guys out there. When listening to the ATC. In my case, Atlanta Center, I often hear controllers clear an aircraft up to an altitude, for this sake, we'll say FL230. And when they do they'll say maintain "normal speed" up to this atitude. What exactly is the normal speed. I realize that it varies for each aircraft, but often times, they are cleared for normal speed when still at 6 or 7 thousand feet. Are aircraft still required to stay at the 250K limit until they get up to 10,000 feet, and then speed up?
Thanx,
Chris
XFSUgimpLB41X
RE: Normal Speed?
Wed Apr 25, 2001 10:58 am
Ah good old Atlanta center, talked to them many many times... which frequency are you listening in on? Normal speed just means their normal unresticted climb speed w/o any speed limits, whether maintaining above or below a certain speed. ATC is allowed to remove that 250 knot speed limit, so i would assume that restriction is lifted when he says that.
I dont have my AIM handy, so i cannot confirm this... i fly airplanes whos redline speeds are far below 250, so i have no experience at this, hehe.
Chicks dig winglets.
LaTechpilot
RE: Normal Speed?
Wed Apr 25, 2001 11:32 am
"Normal speed" is usually given to let the pilots know that a prior speed restriction that was given is no longer needed. Speed restrictions are issued to help separate aircraft arriving or departing a terminal area. Before blasting through 250 knots below 10,000, i'd sure ask the controller if he is giving me permission with the "normal speed" clearance.
RE: Normal Speed?
Wed Apr 25, 2001 12:29 pm
Well, I've got so many frequencies plugged into my scanner. Most of Atlanta's frequencies that I pick up I use to follow arriving/departing planes out of the CLT Class B airspace.
Here's a few:
133.15
134.55
135.35
128.8
119.57
windshear
Is It....
Wed Apr 25, 2001 9:12 pm
Well I do not want ton argue with a pilot, but what springs into mind when reading this is the folowing:
Clearence to activate or follow FMC calculated or pre-programmed speeds.
To leave SID alt. restriction and climb with the calculated airspeed, unique to each acfts behavior.
I do not know which one is the right one, but I know that flight plans and speed settings are known to the tower, so therefor I would think that their filed alt. AND speeds as set on the FMC are given aswell.
OR/AND it could just mean that "normal" is a kind of allowing other speeds, than what is set as a ristriction in the SID papers...
If I'am way off then I have learned something:O)
JYou know I never read or answered these technical questions, not even looked in this discussion room, but having done it, I realize how much I know, crazy hobby:O)
Well I just wanna say that I totally agree with the replies you got. I would have said the same thing.
An additional comment I have is to the fact that it was snowing!!! I s it possible that icing conditions or snow clutter could have disengaged or faulted the APU, as it seems as if it wasn't scheduled or expected by the pilots?!!
Another thing is to a remark by ??? em... In his reply, he wrote that the APU is Diesel driven... As is the case in the 767 I know for sure, is that the APU is fueled from the left wing tank..
Thanx for asking nice questions that I have just the slightest chance of answering:O)
Hope we helped buddy:O)
"If you believe breaking is possible, believe in fixing also"-Rebbe Nachman
windshear
RE: Is It....
Wed Apr 25, 2001 9:14 pm
Just ignore the last thing, which was accidantally pasted from another reply:O)
Sorry for the mess!!!!
RJ
RE: Normal Speed?
Thu Apr 26, 2001 12:24 am
Normal speed refers to preplaned climbout speed issued in the Operation Mode section of the dispatch release. This section contains specific climb, cruise and descent profiles which are used in planning the flight. Altitude selection, fuel requirements and payload have been predicated upon the flight crew following these profiles. They are for the CRJ:
Normal Climb 0.70 Mach (250KIAS)
Normal Climb 0.74 Mach (250/290KIAS)
Normal Climb 0.77 Mach (250/320KIAS)
The (250/290KIAS) refers to 250KIAS under 10,000' and 290KIAS above 10,000.' This is done to comply with the FAR's. THE TERM "NORMAL SPEED" DOES NOT ALLOW YOU TO GO FASTER THAN 250KTS. UNDER 10,000.' (as a side note, Houston has a waiver that if cleared, will allow you to go faster than 250 under 10,000.' The only other place that I've done 250 under 10k is on the MRLIN 4 arrival. The arrival takes you over 12nm off shore. Therefore, you are in international airspace and the 250 under 10k rule does not apply. Controllers there routinly encourage a/c to keep their speed above 250 under 10k! But be carefull of a/c limitations. The EMB-120 had a limitation of 250kts max under 8,000.' This was for bird strike protection)
We have thrust settings that are used depending on which profile we are issued. The Normal Climb Thrust settings for the specified airspeed can be determined from a table for various ambient temperatures and pressure altitudes. The FMS also contains this data, but we are still required to use the charts. And we don't have autothrottles either.
I hope this helps,
Happy flying!
RJ (on strike)
XFSUGIMPlb41x
Thu Apr 26, 2001 2:36 am
Are you telling this person that ATC is allowed to remove the 250 Kt. speed limit? If so you are in error. ATC cannot and will not do that below 10,000' I hope perhaps you were talking about a 250 restriction above 10??
RJ
RE: Normal Speed?
Thu Apr 26, 2001 3:30 am
Uh, Max Power
Where in my post are you reading that? I clearly stated in BOLD print that you are not to exceed 250kts. under 10,000' Not even if you are given the term "resume normal speed". As far as Houston goes, here is a link for you:
http://www.ainonline.com/weeklynews/AIN_weeklynews.html#story5
I indeed have been issued the clearance to exceed 250kts in Houston's Class B airspace under 10,000'
I hope this clears up any confusion.
Happy flying!
RJ (on strike)
RJ
Thu Apr 26, 2001 6:08 am
Mr. RJ, NO I was not refering to your post. I was only making a comment on the post byXFSUGIMPlb41x. His first reply to this post at the top. I am aware of the Houston speed limits and their "test" in that area alone. Not all airspace for sure. Just wanted to let all those that just fly thier lap tops you better not exceed 250 blo 10. I wish you guys all the luck possible, hope its settled real soon in your favor and your back in the saddle soon. Regards, Max
RJ
RE: Normal Speed?
Thu Apr 26, 2001 6:36 am
Max,
Thanks for the kind words and encouragement. We appreciate all of the support that so many in the aviation community have given us. There is a saying around here that states: "Whatever it takes, for as long as it takes"
RJ (still on strike)
XFSUgimpLB41X
RE: Max
Thu Apr 26, 2001 8:34 am
Hey Max, Do you ever read the entire posts or just the parts you want to read? Keep in mind i said i do not have the FAR/AIM in front of me and cannot confirm this. I have been takin finals and did not have the FAR handy. Don't be such an asshole. So, to clarify this, here goes:
FAR Part 91.117
(a) Unless otherwise authorized by the Administrator, no person may operate an aircraft below 10,000 feet MSL at an indicated airspeed greater than 250 kts.
(b) Unless otherwise authorized or required by ATC, no person may operate an aircraft at or below 2,500 feet AGL within 4 nautical miles of the primary airport of a Class C or D airspace area at an indicated airspeed of more than 200 kts. This paragraph (b) does not apply to any operations within a Class B airspace area. Such operations shall comply with paragraph (a) of this section.
(c) No person my operate an aircraft in the airspace underlying a Class B airspace area designated for an airport or in a VFR corridor designated through such a Class B airspace area, at an indicated airspeed of more than 200 kts.
(d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed.
You are right, ATC cannot authorize you to break the 250 speed limit w/o permision from the administrator. Glad we could finally clear this up.. the regs tend to talk for themselves.
And by the way... i hate flight sim with a passion, and also dont own a laptop. Spanks for asking though.
RE: Normal Speed?
Thu Apr 26, 2001 11:00 am
Well, I'm glad we were able to get this little discussion started. In about half my topics, the debate usually turns into real world vs. Flight Sim "hotshots". I for one love the sim, but in no way think it can match the knowledge gained in the real world. Thanks anyways, Chris
By the way, I gotta learn all these regulations, anyone know the closest place to pick up the FAR manual or an AIM? I live in Charlotte, NC
XFSUgimpLB41X
Thu Apr 26, 2001 11:10 am
Im going to rest easier tonight knowing you feel better. Question for you is, why do you post a reply knowing you "cannot confirm this" and just post upon gossip? I don't see the benefit of such a reply? Oh, your welcome for the spanks! You deserved them.  Smile
RJ
RE: Normal Speed?
Thu Apr 26, 2001 12:11 pm
Superslushy,
I would suggest look in the yellow pages for a flight school in your area. Most flight schools will sell that material. If you don't want to do that, you can get all of the material online via the FAA. Go to:
http://faa.gov/atpubs
Click on Aeronautical Information Manual for the AIM.
I hope this helps.
Happy Flying
RJ (on strike)
XFSUgimpLB41X
RE: Max
Thu Apr 26, 2001 3:01 pm
haha, hey everyone deserves a spanking everyonce in a while. I posted that 'gossip" because it is educated gossip and I know quite a bit about the regs and such. Not to mention i get out and fly a whole lot and have quite a few friends that are airline pilots. I dont get a chance to fly jets very much though unfortunately. My company does own a couple CJ1's, King Air 200's and others.... when i get an official position (upon obtaining my CFI/II in late June) i will be flying the jet right seat a whole lot more. Right now i mostly get to run the Saratoga's and dead legs in the archers to pick up pilots. Not exactly the fastest planes around. Peace and humptiness.
RE: Normal Speed?
Thu Apr 26, 2001 7:44 pm
Thanks RJ. By the way, I noticed that you're on strike. Without getting into detail, are you part of the whole Delta - Comair "thing"?
Chris
RJ
RE: Normal Speed?
Thu Apr 26, 2001 11:24 pm
Superslushy,
yes.
RJ (on strike)
Users browsing this forum: skyhawkmatthew and 1 guest
