IL62M Main Wheels Sprayed.
Fri Apr 27, 2001 9:45 am
Was just watching an Aerofloat IL62M parked near the gate.
I noticed that the main wheels were smoking.
Def meaning the brakes has overheated.
The ground crew was spraying the brakes with water.
Is that permitted.Is it not dangerous to spray water on hot wheels.
regds
HAWK.
chdmcmanus
RE: IL62M Main Wheels Sprayed.
Fri Apr 27, 2001 9:53 am
My tech books have a warning that prohibits the use of water on hot brakes, due to the risk of explosion. The only meathod we are allowed to use for cooling hot brakes is forced air. What was the operator, that may explain a lot.
ChD
"Never trust a clean Crew Chief"
Sat Apr 28, 2001 12:49 am
Aerofloat was the operator.
I was surprised they used water for cooling.
Unfortunately I did not get the opportunity to ask them why.
regds
HAWK.
Wasilenko
Sat Apr 28, 2001 10:52 am
AEROFLOT (Air Fleet) not Aerofloat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sat Apr 28, 2001 5:20 pm
You are right. Spelling error.
It is Aeroflot.
But still the question remains.Isn't it wrong to spray water over heated brakes.
regds.
VC-10
Sat Apr 28, 2001 6:16 pm
Yes, the brake unit(s) could explode due to the thermal shock
L-188
Sat Apr 28, 2001 6:56 pm
Hit them with water and if you are lucky all you will do is crack the disks because of the shock cooling on just the parts of the disk the water hits.
Air doesn't have that shock capability and cools more evenly.
galaxy5
Sat Apr 28, 2001 8:03 pm
where was this at? if it was in europe it may have been decon for the hoof and mouth thing. theyve been spraying our wheels and tires down with a chlorine/water mixture.
"damn, I didnt know prince could Ball like that" - Charlie Murphy
VC-10
Sat Apr 28, 2001 8:24 pm
Galaxy5,
It is interesting that you say your a/c are being disinfected with a Chlorine/water mix because Boeing & Airbus have told us not to allow such a solution to be used as it causes corrosion & hydrogen embrittlement if it gets onto the brakes/wheel hubs & landing gear structure
chdmcmanus
Sun Apr 29, 2001 12:30 am
VC-10 is right, US DOD acft have been instructed the same thing.
Wed May 02, 2001 9:54 pm
This occured at Mumbai [Bombay] west coast of India.
under supervision of Aeroflot personnel using a fire engine.
regds
HAWK.
L-188
Wed May 02, 2001 10:00 pm
I was about to say......That clorine should do a wonder job as far as corrosion goes.
Users browsing this forum: FAST Enterprise [Crawler] and 1 guest
