Western727
Heli's
Fri May 04, 2001 7:49 am
Are there any helicopter pilots out there? What type of work do you do, and what is a typical pay range?
Jack @ AUS
Western727
RE: Heli's
Fri May 04, 2001 8:04 am
Also, what certificates and ratings does one need to be a viable helicopter pilot?
Jack @ AUS
Aerotech
RE: Heli's
Fri May 04, 2001 10:40 am
Well, I fly the R-22, but for fun. I was flying it to get my lisence when I was condiering flying the Pavehawk for the Air Force, but then switched to the F-16. B
Basically, you need all the usual stuff like your medical, and either a helicopter lisence or a rotorcraft rating.
Western727
RE: Heli's
Fri May 04, 2001 11:55 am
I've done some checking, and it looks like I'd need the Private Add-On and the Commercial Add-On (Since I've already got about 130 hours of fixed wing (or "powered") time. And it looks like the instrument rating is less important in rotocraft (anyone out there correct me if I'm wrong...),but I'd still want to get that. Also, it looks like heli-training is more expensive, but not as much as I thought.
Jack @ AUS
Aerotech
RE: Heli's
Sun May 06, 2001 2:57 pm
Yeah, most chopper operations are VFR, and helos can get ALL SORTS of exceptions to FAR rules. All sorts from minimum altitude to minimum visibility. So, instrument is a little less important in a chopper. Heli training is far more expensive, the cheapest you can go is the R-22, for roughly $170 per hour and up. Having a good background in fixed wing is good for things like getting to know air routes, ect., but as you''ve probably heard, everything you know about control and traffic pattern ops is out the door! From oval patterns to facing the ground to takeoff, it's all different. Like learning to walk again. But it can be the most thrilling experience of your life. You'll find you have the freedom to go anywhere, it'll be like black magic. I like say it like this: It will be 10 times harder to fly than a plane, but 10 times more fun! Good luck!
Users browsing this forum: BravoOne, Teganuma and 23 guests
