drewwright
727 Compressor Stalls
Tue May 15, 2001 5:00 am
A couple of weeks ago I was watching a AA 727-200 runup for takeoff from MSY on the shorter runway, when it did it's typical howitzer bang/belch, out of the center engine. The pilot seemed to have a high RPM on the engine when it happened. He taxied off the runway and tried again a few minutes later. This time advanced the throttles more carefully. Again at a high RPM there was the Bang followed by a quick series of 8 to 10 bangs and a 20ft flame out the back of the engine. He then taxied back to the gate. A hour or so later he taxied out to the long runway and took off without incident. Why would he taxi back to the gate if compressor stalls are normal like this? There was a very light crosswind of about 5kts at the time, not really enough to induce that kind of stalling.
JT-8D
RE: 727 Compressor Stalls
Tue May 15, 2001 5:09 am
Compressor stalls are not normal on any engine. He went back to the gate, and Ill bet you money they found some kind of crud in one of the filters. Most common problem is a clogged drain orifice on the bottom of the fcu. As discussed in previous posts, the older P+W engines can take a lot of surging before something breaks. I saw a cf-6 come apart after one surge. Not trying to start that argument again though..JT
drewwright
Tue May 15, 2001 5:25 am
I agree that the 727 engine is ultra tough and reliable, even now. Unlike the new engines today that even a minor hiccup results in a teardown. Working for Skywest I once witnessed a CF343 on one of our RJs blow parts out its tail pipe because of a bad airstart. Needless to say that engine was replaced.
JT-8D
Tue May 15, 2001 5:39 am
We had a NG 737 lost about half the turbine do to what we think was flt crew error. He said he just added power to taxi away, and the engine shut down. He started the other engine, and taxied away. Then, for some unknown reason, he restarted the first engine without letting us look at it first. Thats when the real meltdown happened. the redline is 725. The eec showed a peak egt of 743, and above redline for 16 seconds. That will kill the strongest engine made. We found about a pound of metal on the ramp, after the initial failure. City ops found about twice that on the taxiway, where he restarted it. I have my theory on what happened, but I was watching MASH reruns in the breakroom, so I dont know for sure..JT
JETPILOT
Tue May 15, 2001 5:57 am
The 727 has an interstage bleed valve that sometimes sticks open.
The purpose of the interstage bleed valve is when the engine is running at idle the LP compressor sucks in more air than the HP compressor can use. The extra air needs to be bled off the compressor to avoid stalling.
If the interstage bleed valve fails to close when you run up the engine the engine will compressor stall.
Normal 727 operations require a 1.4 EPR check.
On takeoff with the brakes on you stand the thrust levers up to the 12 o'clock position. The engine will accelerate to approx 1.36 EPR. When the bleeds close the EPR will jump to 1.4 EPR. This is the only confirmation you will get that the bleeds have closed.
If the engineer who's job it it to call out "3 stable", or "bleeds closed" depending on company procedures calls them closed and they are not when you advance to TO power......BANG.
Then the CSD oil cooler switch, which bleeds air off the engines also, is placed to ground off and the EPR will jump again to 1.41 approx.
Failure of the interstage bleed valve is the most likely culprit for the #2 surge.
The JT8D engine is really bullet proof. You have to really do something wrong to damage it. The newer engines can't compare in durability.
JET
JT-8D
Tue May 15, 2001 6:10 am
Im not sure what an interstage bleed valve is. Is it the same as prbc (pressure ratio bleed control). Ive just never heard that term before. The #2 engine doesnt have a 13th stage bleed, so Im confused. Can you explain?..JT
drewwright
Tue May 15, 2001 6:11 am
Thanks JET, I figured that the engine was not damaged by the surging antics, just the pilots egos. I would have paid top dollar to be on that flight when the #2 rattled off like that, just to see the faces of the passengers. I suspect the F/A's had quite a few drink orders after the flight finally departed. BTW in my original posting I implied that the 727 compressor stall was common. I meant that only because, when working on the ramp etc, 99% of the time I have heard a compressor stall it has been from a 727. Although I have heard it on the 1011's too.
DRW
JT-8D
Tue May 15, 2001 6:25 am
Ok, been thinking about pilots last post. I think you mean one of the 3 valves that let the air leak into the fan duct? Maybe I learned the wrong term, we call them the bleed control valves, or compressor bleed valves. We did not have the same experiance. Most of our probs were from a clogged filter, or the fcu water trap drain being clogged. A few times it was a stuck prbc, but almost never the valves I think you are describing..JT
JETPILOT
Tue May 15, 2001 7:35 am
No I am probably wrong in my terminology. I remember it being called the interstage bleed valve on one of the planes I flew either the DC8 with the JT3D, or the Beach 1900 with the PT6A-65B, or the 727 with the JT8D. All the info kinda blurs over the years. The closer you get to recurrent the more blured it is.
I just assumed it was called that on all engines and I'm probably wrong.
But the valve no matter what it's called does the same thing.
The valve does leak the excess air into the fan duct.
Maybe it won't cause surging as I described (I was told that in ground school) but the purpose for the 1.4 EPR check is to make sure those valves are closed.
When the valve does close in about 2 seconds after you stand the thrust levers up the needle swings to 1.4 EPR pretty quickly.
I've actually never had an experience on the 727 with a sticking valve. I have had a slow one where it takes longer than the rest to close and causes a slow EPR rise to 1.4.
The only problem I have ever had with compressor stalling, even on the 100 series with the original oval duct (much better looking than the round one in my opinion) is when holding #2 in reverse too long when slowing down. It will begin compresor stalling at about 50 knots in reverse detent.
In an empty freighter, with the sound proofing removed to save weight, it will get your attention.
JET
JT-8D
Tue May 15, 2001 11:30 am
This business will cause "memory decay" wont it? Whatever terms we use, we are talking about the same valve. The check you use to verify valve position seems to be a good idea. You should see the maint manual version of it. What you guys do in 15 seconds, takes us 15 mins. Thanks for your response, info and humor, good combination..JT
FDXmech
Wed May 16, 2001 12:33 am
If the 13th stage compressor bleed valve stuck "open", the most likely outcome wouldn't be a stall but the EGT reaching its limit before attaining T/O EPR. If the bleed valves closed too early, this would likely cause a stall, amongst other things.
The JT8 seems to have more combinations of internal bleed valves than Carter has liver pills. If I remember correctly they reduced the amount of 13th stage bleed valves for more 8th stage ones to increase fuel efficiency. Plus the start bleed system to unload the compressor during start.
JT-8D
Wed May 16, 2001 3:18 am
FDX, there were a bunch of models, but the start bleed valve was added on the -200 series engines. I dont know if they started on the old models, but I know all the -200 have it. None of our older engines had that system. If you have seen the older ones with the start bleed valve, let me know. My instructors told me it didnt exist, maybe a rude E-mail to the training department is in order?--lol..JT
