bio15
Landing On A Crooked Runway
Tue May 22, 2001 8:20 am
I saw a post weeks ago about a crooked runway, and nobody payed much attention. That seems a big deal to me! Why is a two-segment runway even permitted? Even if it is just for light aircraft, the runway should be straightened.
Are there any considerations for a pilot to take when landing on such a runway? And is there any sort of authority that can generate a safety issue about this to reconstruct the runway?
Here's the diagram:
http://www.wehid.com/steensgaard.jpg
-bio
bio15
RE: Landing On A Crooked Runway
Tue May 22, 2001 8:23 am
I forgot to mention that the runway numbers are proper for a straight runway (08/26), why is that?
Monocleman
Tue May 22, 2001 11:16 am
I don't know about any airport in Denmark, but I discovered an airport called Yankee Creek 2, in Alaska, that has a continually crooked runway - I think it has 5 segments that are each about 600' long. I am trying to find pictures of it, if anyone can contribute please do so.
Will
rendezvous
Tue May 22, 2001 3:03 pm
Well I certainly wouldn't like to try take-off from a crooked runway! Obviously it's permitted by authorities, as it exists, but what were they thinking?
Top Gun
Tue May 22, 2001 4:28 pm
I think the diagram is trying to illistrate that runway isn't level. There seems to be a nice rise 2/3 down 08.
Just my two cents.
jwenting
Tue May 22, 2001 4:50 pm
It doesn't. That would have been numbers at the tresholds.
Adding up the directions gives a total of 340 degrees. Normal deviations would lead to 350 at most (5 degrees of on each end), so there looks to be a bend in it somewhere.
I wish I were flying
Dufo
Tue May 22, 2001 10:36 pm
I've also scanned some other interesing stuff from my airfield manuals. Enjoy  Smile
click here
Jernej
I seriously think I just creamed my pants without any influence from any outside variables.
Mit
Wed May 23, 2001 3:00 am
The reason that a some airports exist with crooked runways is that the terrain and money available did not permit a straight one. Very simple.
Clearly the airports are safe, if not ideal. Otherwise you would hear about the rash of crashes.
I don't think such airports are built anymore for public use. Those already around were grandfathered in.
apuneger
Wed May 23, 2001 5:31 am
I wonder how pilots takeoff from this crooked runway. I guess they would try to find a straight line, instead of staying in the middle of the runway, and having to make a turn somewhere. However, if this airfield is used by small planes, I think these small planes should be able to turn during their takeoff roll without too much problems, or am I wrong?
Ivan
Ivan Coninx - Brussels Aviation Photography
ILOVEA340
Wed May 23, 2001 2:59 pm
it really doesn't matter at an airport like that that sees only a few flights per day with very very small planes and gliders.
Top Gun
Wed May 23, 2001 4:16 pm
Jwenting:
I'm not following you when you add up the numbers
(080+260=340) what does that have to do with anything?
01(0)+19(0)=18(0)
Those are just the direction the runway is oriented
either T or M.
Users browsing this forum: conaly and 3 guests
