United Airline
How Does The Air-Conditioning System Work?
Wed Jun 20, 2001 11:06 am
Hey guys!
I am beginning to wonder how does the Air-Conditioning system of an Aircraft work?
Do they have an Oxygen Tank for oxygen supply? Or do they simply take-in Air from the Air, warm them a bit to room temperature and supply it to the Cabin?
America West
RE: How Does The Air-Conditioning System Work?
Wed Jun 20, 2001 11:41 am
>>...simply take-in Air from the Air...<<
 Smile/happy/getting dizzy
It is recirculated during flight (that's all I know Smile)
DC-10Tech
Wed Jun 20, 2001 11:49 am
I feel like I'm being set up, but here is one example: http://extender1.tripod.com look under DC-10 and systems explained. JT, not one word.
Forums.AMTCentral.com
United Airline
Wed Jun 20, 2001 12:27 pm
So, does the plane take-in air during flight?
JT-8D
Wed Jun 20, 2001 12:38 pm
There was a post on this a week or so ago. Several good descriptions were given..JT
DC-10Tech
Wed Jun 20, 2001 12:40 pm
The Cabin Air comes from the engines. It is bled from the engine compressors and ducted through the air conditioning system and then into the plane. The air being forced into the cabin is let out slowly through the pressurization outflow valve. The cabin pressure is then maintained by regulating how fast the air is let out of the cabin.
JETPILOT
Wed Jun 20, 2001 12:41 pm
Air for Pneumnatic Air Conditioning operation is bled off from various stages of the engines compressors. This compressed and very hot air (500 degrees C) is then sent through a pre cooler (heat ecxhanger) to lower the temperature before sending it into the PAC compressor.
The PAC turbo compressor compresses the pre cooled air heating it up again. It then goes through another heat exchanger dropping the temperature before entering an expansion turbine. As the air expands in the expansion turbine it cools very rapidly. This cold air leaves the expansion turbine and supplies the cockpit temperature controlled mix valve with cold air.
The hot air for the mix valve comes directly off the engine bleed after it has ben pre cooled. The wrarm air supplied to the mix valve is bled after the PAC compressor but before the expanson turbine. The position of this mix valve determines the temperature of the air enetering the cabin.
JET
speedbird001
Thu Jun 21, 2001 12:49 am
This subject has been discussed many times previously - try searching the forums. Also, alot if interesting info on the AC systems on Boeing A/craft can be found on http://www.boeing.com/commercial/cabinair/
A simple description can be found, but if you go to "System description (PDF)" link, a PDF file explains the system with the help of diagrams. - Very good explinations.
Hope this helps
Concorde speedbird 001 - fly again soon
Users browsing this forum: akiss20 and 1 guest
