Monocleman
Cockpit Windows
Fri Jul 06, 2001 2:35 pm
In many pictures on A.net, you see the captain or first officer in the a/c waiting for clearance or maintainance workers washing windows with their arms out an open cockpit window. How are the windows in the cockpit opened? And do they lock when the aircraft is in flight? I hope the pilot couldn't slip and press the 'open window' button or something along those lines in cruise... Anyway any and all info is appreciated.
-Will
sushka
RE: Cockpit Windows
Fri Jul 06, 2001 3:03 pm
Look at the little pole next to the window All you do is pull it in or out until the window opens or shuts.
Click for large version
Photo © Ryan Gaddis
Hope this helps!
Pershoyu Spravoyu Litaki!
Monocleman
RE: Cockpit Windows
Fri Jul 06, 2001 3:09 pm
Are you talking about the handle above what looks like the tiller on the f/o's side? On a side note, why does the f/o have a tiller anyway? I thought for the most part they were only installed in the right side.
-Will
sushka
RE: Cockpit Windows
Fri Jul 06, 2001 3:14 pm
Im talking about the pole that is under some papers right up on the window.
A tiller is used for steering large planes on the ground. It makes it easier somhow.
FBU 4EVER!
RE: Cockpit Windows
Fri Jul 06, 2001 8:19 pm
Most airliner cockpit windows are opened by a lever (some planes also have a separate lever that locks/unlocks the window) that slides the window rearwards on tracks.The window itself is larger than the opening,it fits into the opening like a plug and pressurization forces it to seat solidly in place.No way will you be able to open these windows in flight if the plane is pressurized!
Unpressurized,they can be opened in flight in emergencies to remove smoke and fumes that may have built up in the cockpit.
"Luck and superstition wins all the time"!
Users browsing this forum: Mr AirNZ, san747, Yahoo [Bot] and 1 guest
