LY744
Airport Firefighting Categories
Wed Jul 11, 2001 5:27 am
I've got a few questions about the categories that airport firefighting services are divided into:
-How many categories are there?
-What are the criteria that an airport has to meet to be classifide in each category?
-Does the category that an airport is classified in affects the types/number of aircraft it is allowed to serve?
Thanks in advance,
LY744.
dispatcher
RE: Airport Firefighting Categories
Wed Jul 11, 2001 9:25 am
In the U.S. there are 4 categories of ARFF (Airport Rescue and Fire Fighting) A,B,C & D, with A having the least capability and D having the most. For example an 'A' class airport has at least one crash truck with 500lbs of dry chemical or Halon. ICAO requirments are different, with categories ranging from 1-9, 9 being the best. Once again an example of a class 6 airport would have at least 2200 gallons (8300 ltrs) of water for mixing of foam and at least 500lbs (225 kgs) of dry chemical. The airports index can actually change at different times of day due to fire station manning, equipment maintenance, etc. My experience is with cargo operators so I'm not sure if it applies to pax carriers or not but we can operate into a class 'A' airport with up to an MD-11 domestically and a class '6' internationally using ICAO standards. I'm not sure where to find more info on line about the ICAO stuff but you can find all the info you ever wanted to know about this in the U.S. under FAR 139 subpart D. Here is a link to that section. Just type 139 in the right box and do a search, then look at sections 139.315,317, & 319.
http://www1.drive.net/evird.acgi$pass*6323729!_h-www.landings.com/_landings/pages/search_fars.html
Wow, that's longer than I thought but just copy and paste it.
Hope this helps!
LY744
Wed Jul 11, 2001 10:55 am
Thanks a lot for your reply and the link, Dispatcher!
Can anyone help me with the ICAO categories?
LY744.
Users browsing this forum: ARNPEK, Google Adsense [Bot], Iemand91, zknzf and 2 guests
