Fuel Reserves
Thu Jul 12, 2001 7:38 am
I know that for IFR flight an aircraft needs enough fuel to get to it's point of intended destination, then the alternate, and then 45 minutes more of fuel at cruise burn.
Here's the question: Generally speaking, how often do air carriers fly out with just the minimum 45 minutes of reserve? I suspect that's probably enough for flights around the U.S., but do long-hauls usually carry more? On a 10+ hour flight it seems all it would take is a small shift in the winds and that reserve would be gone.
seagull
RE: Fuel Reserves
Thu Jul 12, 2001 9:42 am
No, long hauls generally don't carry more. Usually the minimum plus some contingency.
That said, the international requirement itself is a bit different. being flight to destination, + then add fuel for 10% of the time required to destination (different than just 10% of the fuel to destination due to weight change at arrival), plus fuel to the most distant alternate, plus 30 minutes holding fuel at 1500' above that alternate.
To reduce the 10% value most long flights are "rereleased" enroute so the the 10% factor is less, since the 10% can be calculated from the rerelease point. We are therefore initially released to a point short of the final destination, then at some point close to where we'd have to break off and fly to that point, we are "rereleased" to the final destination. All of this does not involve ATC unless we have insufficient fuel for the rerelease, and then we must continue to the original "released" destination.
In the end, we land with about what we would with the destination plus alternate plus 45 minutes, or pretty close to that. Some extra fuel may be added for weather or ATC contingency, but usually the 10% values cover all of that. The exception is very short flights that are international with close in alternates. Most of us (the pilots) have personal minimums which we look for which short cuts around all of this. I don't really care that much about all these rules if I have enough to get to my destination, then to my alternate and some comfortable reserve amount (I like 45 minutes), with extra for weather I think may be a factor, etc.
One more note is that domestic air carriers are not required to have an alternate if the weather is above certain criteria.
Users browsing this forum: bob606 and 1 guest
