modesto2
Ceiling And RVR For CAT I, II, III
Fri Jul 27, 2001 6:23 am
I apologize because I know this information has been posted (but I can't find it). What are the ceilings and RVRs for the different approaches? Thanks.
SQ325
RE: Ceiling And RVR For CAT I, II, III
Fri Jul 27, 2001 9:48 am
Cat1= RVR 550m ceiling 200ft
Cat2= RVR 300m ceiling 100ft
Cat3= RVR 100m??? ceiling 60ft to 0ft Cat 3C
OPNLguy
Fri Jul 27, 2001 9:47 pm
From the AIM at: http://www.faa.gov/ATpubs/PCG/pcg-i/pcg-i.html
ILS CATEGORIES
- 1. ILS Category I. An ILS approach procedure which provides for approach to a height above touchdown of not less than 200 feet and with runway visual range of not less than 1,800 feet.
- 2. ILS Category II. An ILS approach procedure which provides for approach to a height above touchdown of not less than 100 feet and with runway visual range of not less than 1,200 feet.
- 3. ILS Category III:
a. IIIA.-An ILS approach procedure which provides for approach without a decision height minimum and with runway visual range of not less than 700 feet.
b. IIIB.-An ILS approach procedure which provides for approach without a decision height minimum and with runway visual range of not less than 150 feet.
c. IIIC.-An ILS approach procedure which provides for approach without a decision height minimum and without runway visual range minimum.
me
Tue Jul 31, 2001 2:09 am
Ceiling is not a requirement for any ILS approach. Visibility must be at or above the minimum published for the approach for an airliner to pass the finial approach fix.
Example:
ILS CAT I approach with minimums of 200ft and 1/2 mile vis can be flown with the ceiling below 200 feet but not with the vis below 1/2 mile.
sabenapilot
Tue Jul 31, 2001 11:08 pm
Me,
I think OPNLguy ment DH i.s.o. ceiling.
Anyway,
a ceiling is sometimes required on ILS approaches!
for instance: Brussels' simultaneous dependant ILS approaches to the RWYs 25L and 25R.
Users browsing this forum: battlegroup62, Moose135 and 22 guests
