121.5
Mon Jul 30, 2001 1:40 pm
is 121.5 the universal comm channel for emergencies? i know it is in the USA
Buff
RE: 121.5 MHz
Mon Jul 30, 2001 3:04 pm
Yes. Additionally, 243.0 MHz, the first harmonic of 121.5 MHz.
Best Regards,
Buff
mightyfalcon
RE: 121.5
Mon Jul 30, 2001 3:06 pm
Yes it is and pilots and ATC are monitoring it.
121.5 is the emergency frequency for civilian traffic while military are using 243 MHz.
Some military, like the US Navy P3s are monitoring both frequencies.
The sky has no limit...
apuneger
RE: 121.5
Tue Jul 31, 2001 7:32 am
So, should I have a scanner, and I tune it in on 121.5, the only thing I will hear (if there's someting to listen to of course...) will be aircraft with some kind of emergency?
Let's hope that I won't hear too much chatter on this frequency..Now, the only thing that I still have to do, is buy a scanner...
Ivan
Ivan Coninx - Brussels Aviation Photography
RE: 121.5
Tue Jul 31, 2001 7:38 am
>>So, should I have a scanner, and I tune it in on 121.5, the only thing I will hear (if there's someting to listen to of course...) will be aircraft with some kind of emergency?<<
In the UK we can do practice emergencies and do practice pans on that frequency, pretty fun stuff!
Iain
airplay
RE: 121.5
Tue Jul 31, 2001 10:58 am
I think most of what you'll here on those frequencies are people testing their ELTs. You'll have to be pretty close to and airport though.
Some ELTs being installed these days also transmit on 403 MHz. They transmit serial data to a satellite including the last aircraft position from the FMS/GPS if it's connected.
Junior
RE: 121.5
Tue Jul 31, 2001 5:59 pm
Another thing you'll hear might be ATC trying to get in contact with an aircraft. It happens sometimes that you lose contact (e.g. fly out of the range of the previous controller without getting a new frequency) and can't find an appropriate new one on the charts. 121.5 might be of good help. Some ATCOs are aware that most flights monitor 121.5 and try to establish a connection like this, or you may ask some collegues for the correct freq.
Users browsing this forum: GrayMatter and 10 guests
