UA752
Airliner Door Questions
Fri Aug 17, 2001 1:22 am
Ive noticed that on most airliners there is some sort of "strip" of metal that proceeds diagonaly along the fuselage...what is this and what's its purpose?
Also I have noticed that on lots of jets that the metal directly below the door is not painted...why is that?
Heres a good example of what Im talking about...
Click for large version
Photo © Bill Paulsen
MSN
flight152
RE: Airliner Door Questions
Fri Aug 17, 2001 1:41 am
It channels the water around the door so the passnegers don't get wet when leaving/boarding the plane. Kinda like a gutter, in fact my mom's Volvo S90 has them too!
JSchultz
Fri Aug 17, 2001 1:48 am
That metal strip at the bottom of the door is a scuff plate. They aren't painted for obvious reasons...(Jetways, boarding stairs bump up against them).
Jim
UA752
Fri Aug 17, 2001 1:50 am
hmm....simpler than I thought...thanks again
MSN
musang
Fri Aug 17, 2001 2:20 am
Those rain gutters above the doors are, on some types, angled to align with the local airflow, to cause less drag.
Therefore you might see one at a forward door sloping down towards the front, and one on a rear door sloping down towards the rear. On other types they're all horizontal.
To get an illustration of the direction of flow along a fuselage, look for one with toilet fluid leaking from the forward servicing panel!
Regards - Musang
Klaus
UA752
Fri Aug 17, 2001 3:35 am
UA752: Also I have noticed that on lots of jets that the metal directly below the door is not painted...why is that?
Another possible explanation is given here: http://www.concordesst.com/model102/pop9.html
I don´t know if this problem is also relevant on subsonic planes; But helicopter rotors are known to pick up static electricity while they are moving through the air.
So this unpainted area below the airbus door might be used to discharge the fuselage in a controlled way in order to spare an unsuspecting passenger...
Seems a little small for mechanical protection.
Do jetways usually have brush contacts in this area?
Notar520AC
Fri Aug 17, 2001 8:30 am
"Helicoper rotors tend to pick up static..."
Yes- they do. From a helicopter pilot, we have static discharge areas aft and fore on the fuselage. They're very small though- only about the size of a half dollar and are never covered.
BMW - The Ultimate Driving Machine
Users browsing this forum: HighBypass, sadiqutp and 1 guest
