BA
Where Are The APU's Located On The BAe 146/Avro RJ
Mon Aug 20, 2001 8:27 am
I know that the BAe 146 and Avro RJ have four APUs. Where exactly are they located?
Any help would be greatly appreciated.
Regards.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
scaredflyer21
RE: Where Are The APU's Located On The BAe 146/Avro RJ
Mon Aug 20, 2001 9:24 am
I believe one of the APU's is located under the first officer, thats what the ramp agent told me anyway.
wilcharl
Mon Aug 20, 2001 12:33 pm
there are 4 Avco-Lycoming ALF-502 APUs under each wing, the exhaust points aft and by pointing it to the aft, our friend newtons laws of motion kick in and the opposite reaction thing makes the aircraft move forward
this thrust counteracts the drag. and not to get into aerodynamics, but the aircraft magicaly lifts off the ground thanks to the ingeniuus placement of the 4 apu's since they did this the 146 doesnt require any ENGINES!
Metwrench
Mon Aug 20, 2001 4:20 pm
It's located in the empenage aft of the rear pressure bulkhead. Mfg. by Garrett, now a days known as Honeywell. When running at it's max it is capable of powering up one each; AC gen. DC gen, and two AC packs. However, if you try and utilize this unit to it's full capacity it is likely to explode and expell the turbine rotor right out the "S" duct onto the ramp as I have have witnessed.
Mon Aug 20, 2001 8:46 pm
Are you Sure FOUR APUs???.
It should be 1 APU & 4 Engines right!.
regds
HAWK.
sabenapilot
Tue Aug 21, 2001 12:19 am
Indeed-
the BAe146 has 5 turbine engines:
one in the tail and 4 under the wing.
luv2cattlecall
Tue Oct 14, 2008 8:32 am
Quoting HAWK21M (Reply 4):
regds
HAWK.
It's a joke  Wink Think A340...
Tue Oct 14, 2008 9:31 am
Quoting Luv2cattlecall (Reply 6):
It's not as much of a joke as you think. Those cores are also used as APUs.
luv2cattlecall
Tue Oct 14, 2008 10:35 am
Quoting Starlionblue (Reply 7):
Good point...but just because the A340's engine core can be used as an APU on a CRJ doesn't mean the A340 has four haird.....APUs!
Tue Oct 14, 2008 11:27 am
Quoting Luv2cattlecall (Reply 8):
The Avro's cores, not the 340's.
wn700driver
Tue Oct 14, 2008 2:26 pm
Those references to the A340 (200 & 300) having 5 APUs are just plain unfair. Everyone knows those things under their wings are hairdryers.
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
Jetlagged
Tue Oct 14, 2008 2:36 pm
Hairdryers with 32,000 lbs thrust each. Don't get your head too close to the nozzle.  Wink
EMBQA
Tue Oct 14, 2008 3:31 pm
Quoting Scaredflyer21 (Reply 1):
No.. the only APU is mounted back in the tail...but the 'joke' of this thread is the 4 engines used on the BAe 146 and Avro's are also used in their core form as APU's on bigger aircraft.
Northwest727
Tue Oct 28, 2008 12:21 pm
I thought the engines used on the BAe146/Avro RJ are actually derivatives of helicopter engines...?
Jetlagged
Tue Oct 28, 2008 2:07 pm
Quoting Northwest727 (Reply 13):
Yes indeed, the Lycoming T55 as used in the Chinook, but that's not such a good joke, apparently.  Smile
Users browsing this forum: Baidu [Spider], Google [Bot] and 9 guests
