Darius
A310 Slats At The Gate
Tue Sep 11, 2001 10:21 pm
Can any body tell me why the slats of an A310 are often (but not always) deployed when the a/c is at the gate? All other a/c I know retract the slats after landing (I don't know about the A300 though).
Below two pictures of A310's at a gate, with different slat positions.
Click for large version
Photo © Ingo Richardt
Photo © Antonio Saraiva
musang
RE: A310 Slats At The Gate
Thu Sep 13, 2001 3:41 am
I asked an engineer the same question a few years ago and he said its simply to reduce wear on the actuators. It effectively saves one slat extension/retraction per flight cycle.
The A300 does the same.
Regards - Musang
Thu Sep 13, 2001 7:40 am
It may also have to do with the systems on the airplane. The 727 slats are hydraulic powered and they have a big tendency to droop when the pressure is turned off for shutdown as well as other flight control surfaces. This is true for alot of airliners when parked at the gate the stablizer is sitting with different positions on each side(Boeing anyway) as well as ailerons and such. The 747-400 slats are pneumatically powered.
310_engineer
RE: : ChrisHabgood
Thu Sep 13, 2001 8:27 am
What you are saying is only possible with the Krueger flaps. They are controlled by an hydraulic actuator, but the slats are controlled by screwjacks, gearboxes and torque tubes which are driven by a PDU (Power Drive Unit). The PDU is a sort of hudraulic motor.
Darius: the reason is explained by Musang
Mike
RE: : ChrisHabgood
Sat Sep 15, 2001 4:36 pm
I wasn't saying it about ONLY the kreuger flaps, it was a comment on the type of system the airplane uses. Alot of airliners control surfaces droop when the hydraulics are turned off and the pressure releases from the controls.
310_engineer
RE: ChrisHabgood
Sat Sep 15, 2001 8:15 pm
FYI We are talking about an A310 here and the slats just can't droop for the reason I explained in my previous post.
VASI
Tue Sep 18, 2001 4:12 am
Hello!
As T know the MD-80 retracts the slats to 15° after landing and when taxiing to the gate and vice versa to the runway. This should prevent the engines from ingesting debris, but I don't know if this is really effective!
Best regards!
VASI
RyDawg82
Sat Sep 22, 2001 8:09 am
I have never seen the MD-80 leave the slats down after retraction of the flaps...What airline practices this???
VASI
Rydawg82
Sun Sep 23, 2001 1:24 am
Hello!
I meant slats + flaps. I've seen this on SAS MD-80's
and Iberia MD-87's.
To my knowledge it is also compulsory in the normal "after landing checklist" to set the slats/flaps to 15° degrees after landing, to prevent this foreign object damage. The most importnat phase is during taxi, not at the gate!
Best regards!
VASI
RE: Rydawg82
Tue Sep 25, 2001 10:28 am
A major cause for the -80's being taken out of service is ground vehicle operations at least with the passenger airlines. At least at UPS we would NEVER have ground vehicle contact problems with flight control surfaces hanging out due to we NEVER EVER go under a wing/Horizontal stab.
A310 Engineer
Tue Sep 25, 2001 10:32 am
I was not rying to get into a discussion about the airbus primarily beacause airbus is SO much different than boeing I have not read up on systems with the airbus. My comments were only based on general systems or specific airplane systems knowledge based on the 727 or 757/767/747-400 type of systems.
DC-10Tech
Thu Sep 27, 2001 4:43 pm
Musang is absolutely right. At Express.net, the policy is to leave them deployed unless the aircraft will RON. At FedEx, I believe they retract them.
A310's and 300 have been known to have a lot of problems with the torque box failures (or, the plane thinks they have) and saving cycles sure helps out a lot with delays!
Forums.AMTCentral.com
Users browsing this forum: Omykron, Taxi645, Woodreau and 17 guests
