david b.
What Are Those
Sun Oct 07, 2001 11:58 am
On some planes I seen, a small long piece of metal protudes from the wing. I can't find a pic of it but seen it many times. Its located on the very end about a foot or two long. Im not sure if you understand what im talking about, but if you do, then you can answer my question:
What is that and what is used for?
Teenage-know-it-alls should be shot on sight
david b.
RE: What Are Those
Sun Oct 07, 2001 11:59 am
Is not a winglet, It looks sort of like a antanna.
Qantas737
RE: What Are Those
Sun Oct 07, 2001 12:24 pm
Do you mean the piece at the end of the wing of say for expample a 747-100/200/300? I have also been wondering what exactly that is for.
I Like To Fly
RE: What Are Those
Sun Oct 07, 2001 12:25 pm
Are you talking about what was discussed here:
http://www.airliners.net/discussions/tech_ops/read.main/22499/4/
That would be my best guess. Smile
OPNLguy
RE: What Are Those
Sun Oct 07, 2001 12:42 pm
Based upon your description, it sounds like either a fuel dump nozzle...
Click for large version
Photo © Peter D. Baumgartner
Photo © Richard Zeman
..or on the older 747s, and HF (high frequency) radio antenna...
Photo © Wilsam Cheung
If neither of these are it, any other details you can recall would be helpful...
Buzz
Antennas
Sun Oct 07, 2001 11:58 pm
Hi David B, Buzz here. I'm used to seeing the High Freq. radio antenna on the wingtips of the older 747's. Let's see, the old 707's had it pointing forward from the vertical fin...... so it could spear birds? (grin)
On 757's, 737's and 767's it's built into the leading edge of the vertical fin.
On DC-8's it was built into the top 5 feet of the vertical fin. I can't remember where it was on a DC-10.
Why use HF? because it's a (relatively) low frequency (2,5 -- 20 hz) and it bounces off the ionosphere for long range communication. The normal VHF radios are line-of-sight only, once you get 150 miles away you're out of sight....... that is if the Earth really is round.
HF radios are not easy to talk / listen on. Lots of things interfere with the signal you want to listen to. It's like listening to AM radio at night sometimes. But from the Pacific Northwest (USA) i can hear the Aussie BBC, and time signals from Ft Collins Colorado.
g'day
david b.
RE: What Are Those
Mon Oct 08, 2001 2:51 am
Yep, that little antanna was a HF antanna. THank you guys.
air2gxs
RE: What Are Those
Mon Oct 08, 2001 7:29 pm
Little? The thing is every bit of 4 ft long if its a foot.
Users browsing this forum: GalaxyFlyer, Google [Bot], IPFreely, mxaxai and 1 guest
