M80
DC-10-30 V Speeds?
Tue Oct 23, 2001 12:38 am
I'd like to know some takeoff V speeds for DC-10-30, takeoff weight let's say 500 000 lbs / ~230 000 kgs
V1
V2
Vflap ret
Vslat ret
Thanks in advance.
Kalle
XFSUgimpLB41X
RE: DC-10-30 V Speeds?
Tue Oct 23, 2001 12:57 am
DC-10-30 at 380,000 pounds out of MSP at FLEX temp 49 degrees Celsius and STP (I can't my 580,000 pound TOGA sheet):
V1- 130
Vr- 136
V2- 148
Vf (minimum speed to start retracting the flaps at)- 163
Vzf (minimum clean wing speed)- 231
Optimum climb speed: 293
T/O N1= 102.5%
For a 508,000 pound DC-10-40 (less powerful engines), at FLEX 00 temp and STP out of DTW:
V1- 162
Vr- 166
V2- 177
Vf- 196
Vzf- 267
Optimum climb speed: 320
T/O EP= 1.51
The -30 speeds are a bit less than these as it has much more powerful engines.
Chicks dig winglets.
XFSUgimpLB41X
Tue Oct 23, 2001 12:59 am
I forgot, this is with Slats in takeoff position and 19 degrees of flaps for the -30, and 22 (or maybe 24...) degrees of flaps for the -40. It's been a while since ive been in the plane and some of the little differences between the two aircraft are clouding themselves together.
XFSUgimpLB41X
Tue Oct 23, 2001 1:02 am
also.. that first sentence in the first post should read: I can't FIND my 580,000 pound TOGA sheet.
Blackbird
Tue Oct 23, 2001 7:34 am
I thought the DC-10 had
Flaps Up, 0 (slats), 5, 10, 15, 22, 35, and 50 degrees
And slats 15 at flaps zero, 35 at flaps 35, and 50 degrees at Flaps 50.
There's also a dial-a-flap, as a customizable flap-setting that enables you to select a flap setting from 1 - 21 degrees I think.
I know on the MD-80 there's a similar dial that enables a custom setting from either 18, or 23 flaps. The idea is that you can use 18 for a takeoff or 23 on long final for slowing down. Useful because going to 28 without the gear will elicit an irritating warning sound. 23 without the gear enables you to avoid the warning sound, and slow down a bit, drop the gear, and go to 28. At least that's what I think.
-Andrea Kamarov
DC-10Tech
Wed Oct 24, 2001 12:44 pm
No, the DC-10 Flaps/Slats are as follows:
Flaps/Slats
up/retract
0/takeoff
15/takeoff
22/takeoff
35/land
50/land
Plus dial a flap with slats at takeoff.
Forums.AMTCentral.com
XFSUgimpLB41X
Wed Oct 24, 2001 1:03 pm
The NW -30's have the notches at up, flaps 1(slats only), 19, 24, 35, and 50.
The -40's have the settings as you descibed.
Users browsing this forum: c933103, fortytwoeyes, MSNbot Media and 1 guest
