DC10Tony
DC10 & L-1011: Wing And Flap Question
Sun Oct 28, 2001 12:36 am
On the DC-10, why are the wings almost perfectly straight, while on the L-1011 they're curving upward?
On the DC-10, why are the rear horizontal stabilizers curved upward, but on the L-1011, they're perfectly straight?
Are there any advantages or disadvantages for each design, or one plane compared to the other?
RE: DC10 & L-1011: Wing And Flap Question
Sun Oct 28, 2001 10:04 am
The L-1011 has a slat locking system that the DC-10 lacks.
DC10Tony
Sun Oct 28, 2001 11:46 am
Ok, but what's a slat locking system and how is it relevant to my question?
DC-10Tech
Sun Oct 28, 2001 12:12 pm
The upward curving you're speaking of is call 'Dihedral'. While the DC-10 wing appears to be straight, it is actually called a dual dihedral because the wing roots actually curve up quite a bit until they meet the less-curved part of the wing near the pylons. Dihedral increases stability about the roll axis. The difference between the dihedral on the stabs of each aircraft may be due to the different configurations between the #2 engine arrangement. Just remember that the engineers designed these aircraft after a lot of wind tunnel testing, and the design of each aircraft has been found to be the best combination of aerodynamics, handling, and efficiency in the wind tunnel.
Forums.AMTCentral.com
Buzz
Mon Oct 29, 2001 1:30 am
Hi Dc10tony and Tedski, Buzz here. I'll have to disagree with Tedski, since that AA DC-10 roll-over-and-die at ORD, the DC-10 have had a lock installed on the leading edge slat drive wheel and cable. Yes, there is a big wheel that pulls cables, thumped my head on it a few times. And i like Lockheed aircraft, we only had 6 of the L1011-500's to compare with the almost 60 DC-10's we were flying.
I'm not an expert at aerodynamics, but one thought: There's a mighty downwash of air coming off the wing, sometimes the horizontal tail has a lot of dihedral to get some of it out of the downwash as you get to higher angles of attack.
g'day
Buzz Fuselsausage: Line Mechanic by night, DC-3 Crew Chief by choice
mirrodie
Mon Oct 29, 2001 2:17 am
Can anyone show a vid or link showing Flap ops on the 1011??
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
Users browsing this forum: 67ponajrad, jetmechanicdave and 2 guests
