Diego
Thermal Runaway
Tue Nov 13, 2001 7:36 am
Hi folks, is there any body out there among those mech wizards willing to explain to me what is a thermal runaway, what action are you expected to take if your battery temperature gets to high, if any other than to isolate the affected battery and what in the world the reset button of a starter generator does, (I read it resets an overvoltage circuit but I don't have any clue when that tripped)?
THANKS DIEGO
RE: Thermal Runaway
Thu Nov 15, 2001 7:33 pm
Hi Diego
Thermal runaway is not nice!! It is caused, primarily, by heat build up in a battery during charging - usually due to over-charging. The effect of the temperature is to increase the internal resistance of the battery to the charging current which in turn leads to even more heat, then more resistance, then more heat etc., etc. and voila ...thermal runaway - very nasty, exploding batteries, nasty smells and so on. Avoid, if possible, by isolating electrically which will cut off the charging current. Allow to cool down and FIND OUT WHY!!  Smile
L-188
RE: Thermal Runaway
Thu Nov 15, 2001 7:56 pm
Lets see if I remember this right.
Correct me if I am wrong, it has been a year and a half since I had the DC electronics class.
On a ni-cad battery, what has happened is that the Celophane that seprates the plates in the battery have litterally melted, for the reasons that Old Virgin mentioned. That celophane acts as a barrier between the plates in the battery and the "electrolyte" in the batteries. Because that barrier is gone, the plates are free to oxdize(I know that isn't the right term. It is 2AM here OK) uncontrollably.
What do you get when you allow something to oxidize uncontrollably. Sometimes rust, but in this case your battery is in the scientific venacular......ON FIRE!!!
Like I said, I am trying to see if I remember what they where teaching a year and half ago, so if I am out in left field, don't torpedo me too harshly.
fr8tdog
RE: Thermal Runaway
Mon Nov 19, 2001 12:20 pm
NiCads will have a thermal runaway with a rapid discharge also, I.E. during a start, with a turbo prop.
The Sf340 will draw over 2000amps during initial rotation then down to 800amps once the starter starts to spool up and gain momentum.
Users browsing this forum: Baidu [Spider], CV990A, cylw and 1 guest
