wardialer
Rate Of Acceleration To Vr Speed?
Fri Nov 16, 2001 1:07 pm
What is the rate of acceleration to rotation speed of an B747-400 or an A319. Rate of acceleration being in = Knots per second (Ground Speed) on a standard day OAT =15C BARO (QNH)= 1013MB Wind= 0
Skystar
RE: Rate Of Acceleration To Vr Speed?
Fri Nov 16, 2001 8:56 pm
These are some rough whole numbers (just using some scenarios in my head).
A319 - 4 to 7kt/sec
B744 - 3 to 5kt/sec
Basically, if you want to work it out, just divide Vr by the takeoff time. Eg, rough figure for 744 at MTOW, 170/50=3.4kt/sec
A340 (269ton at ISA+12): 160/55=2.91kt/sec
There are so many factors which can affect this, because of weight and thrust derates involved. Some may be able to help you with the physics of it, but they tend to ignore other drag factors (generally consider only thrust & weight).
Justin
Users browsing this forum: TailDragging and 1 guest
