hoons90
Can The 732 Engines Be Converted Into 734 Engines?
Fri Nov 16, 2001 8:49 pm
Can they?
The biggest mistake made by most human beings: Listening to only half, understanding just a quarter and telling double.
Skystar
RE: Can The 732 Engines Be Converted Into 734 Engines?
Fri Nov 16, 2001 8:57 pm
Nope.
They are different, the JT-9D and the CFM56-3.
The chief reason is the difference in size - the CFM56-3 wouldn't fit under the wing of a 732 - it barely fits under a 733/4/5's wing.
Justin
SailorOrion
Fri Nov 16, 2001 10:15 pm
No they can't.
SailorOrion
L-188
Fri Nov 16, 2001 10:47 pm
If somebody is willing to spend the money anything is possible.....
But at this point nobody is willing to spend the money.
If there every was a 737-200 reengineering that was proposed I would suspect that they would look at the Tay or the BMR-710 engines as a replacement.
But I don't think the economics will support that work being performed.
Sat Nov 17, 2001 1:18 am
Skystar...The B737-200 has JT8D powerplant not JT9D.
The B737-3/4/500s use CFM56-3 engines.
The attach fittings differ.
But I'm sure it can be made compatiable but it would prove expensive.
regds
HAWK.
yyz717
Sat Nov 17, 2001 2:12 am
There was talk back in the early-mid 80s of a 732 reengining program with CFM. Called the 737-250. Around the time the 733 came out and before the 735. There was obviously no airline interest.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
AA737-823
Sat Nov 17, 2001 4:17 am
No. The biggest reason is that the 732 sits much lower to the ground than the 733-4-5. Because of this, the engine nacelle on the 733/4/5 is flat at the bottom (you've noticed). They had to extend the landing gear to make the plane "taller" even with the flat bottomed engine.
The underbelly/wheel/wingbox area would have to be replaced.
When you get down to it, there isn't much point. Since 737s are still manufactured, just buy a new one. With 727s, it becomes a sensible thing to do.
Randy
Skystar
Sat Nov 17, 2001 12:58 pm
Hawk21M,
Good point - the -9D is a tad larger than an 8D  Smile
Justin
Sat Nov 17, 2001 1:25 pm
AA737-823....
Could you confirm that the MLG of the 732 is different from the 733/4/5.
I'm talking ONLY of the landing gear.
I'm aware of the 737NGs having a different MLG.
Pls confirm.
skystar....JT9D is used on the B747.
regds
HAWK.
L-188
Sat Nov 17, 2001 6:16 pm
I supposed you suppose that you could mount a pair of JT9D on a 737 but you probably only need one.....
IF you went with two engines would would have to mount them overwing....much like the AN-72
Skystar
Sun Nov 18, 2001 10:22 pm
Yep, I know.
It's also on the 767 - old QF762s have them.
Justin
Mon Nov 19, 2001 2:49 am
Is the MLG of the B732 the same as the B733/4/5.
regds
HAWK.
Users browsing this forum: 77west, Bing [Bot], Raventech and 2 guests
