Blackened
Take-off Distance - "hot And High"?
Wed Nov 21, 2001 6:58 am
Can anybody please explain how it comes that aircraft need a longer distance for take-off when the airport has a higher altitude or when it's hot?
When it's higher the air is thinner but why is hot air thinner? Doesn't hot air have a higher pressure than cool air?
Bring it back, bring it back, bring it back
SQ325
RE: Take-off Distance - "hot And High"?
Wed Nov 21, 2001 7:06 am
Hot air is thinner because an molecule of air geting hotter it is moving faster and needs more space.
So hot air is thinner than cold air because of the movement of the air molecules.
regards SQ
peterba69
Wed Nov 21, 2001 7:56 am
Warm air is less dense, thus has fewer molecules/unit, requiring more distance for T/O. Add altitude to it and you come up w/ a combo called density altitude. There's a formula that pilots use to calc. T/O length that factors this, and some A/C might even be temporarily grounded at high alt. airports 'til it cools down. Hope this helps.
Peter
timz
Maybe You're Confused...
Wed Nov 21, 2001 8:24 am
...about the difference between pressure and density.
You said hotter air is higher pressure, meaning that if you heat up air in a sealed container the pressure increases. Sure enough. But at a given pressure outdoors, hotter air is less dense-- and density is what matters to the pilot.
prebennorholm
Wed Nov 21, 2001 10:13 am
Also keep in mind that hot air reduces engine performance.
So hot air works double against take-off performance. On the wings, and inside the engines.
cedarjet
Sun Nov 25, 2001 4:27 am
That's why a lot of flights in the ME are at night, it's safer. I have been grounded at Dubai (which is almost at sea level) cos it was so hot. We left at 3am in the end.
Av8trxx
A/C Performace & Density Altitude
Sun Nov 25, 2001 6:28 am
In addition to the posts already offered, this page provides helpful explainations of how air temperature and density affect a aircraft performance. While it refers to props, the many of the same principles apply.
"Aircraft Performace, Chapter 4"
http://avstop.com/AC/4-10.html
